Hello guys,
Just after some advice on lowering the front of my KE20. I want to lower it at least 2 inches, and I'm aware you can't buy actual Corolla ones that will do that. My brothers both lowered their KE30s with King springs for a Laser (KRML-23 I think the part was). Do these same springs fit a KE20 or no, and if not what are some of my other options? Thanks in advance.
The cheapest, easiest and probably safest way to do it (failing buying pre-made springs) is getting the original springs re-set by a suspension specialist - it's the best way to gaurantee you get the height you want too.
Angle grinder is cheap but if you want handling and safety i woulnd't go there....
Alternatively, try other brands of spring (K-Mac, KING SPRINGS, Pedders etc).
So does anyone know whether the Kings superlow rear laser springs fit KE20s as well as KE30s?
This is some info Suerjamie once gave me.
ke30 and 55 have same diam coils (big)
ke20 and 25 and 70 have same diam coils (small)
So that would suggest that KE30's and KE20's have different Diameter coils. So if Laser springs fit in a KE30, they most probably wont fit a KE20.
A quick search of the major spring brands found this:
Lovells
10/70-10/74 KE20-26 Sdn/Wgn
Super Low TFL-29SLA =45-65mm Lower
Low TFL-29A =25-40mm Lower
King Springs
70-74 COROLLA KE 20-26
Low KTFL-28 =30mm Lower
Lovells
King Springs
Thanks, I'll look into those ^^
Ebay
I bought my Lovells Super Low springs from this bloke. You just tell him what model car you have, and he orders the parts in for you. $105/pair is $45 cheaper than the Lovells Distributor. He is more than willing to post and is very pleasant bloke to deal with.
KYB
He also is able to do great deals on KYB shock absorber packages. I bought a complete set for my car.
Its a fair price, considering Pedders quoted me $700 for their comfort gas range.
Edited by kangaroosa
