Ke30 2 Door Project
that looks really neat now, but the brown handbrake thing looks out of place, go to the wreckers and get a black one and she will be sweet as, seats look realy good to
  • Replies 30
  • Views 8.3k
thats what i thought too thats why i pulled the black one out of my spare parts car before i got rid of it.
i think you sit just a touch higher and the side support is unbelivable they feel like recaros they wrap right around you
WoW, i've never seen that before. Is it just brown?? If i had that i'd see if i could get it covered in some sort of wood grain vinal. Now that would look sick.
its out of a early 70s celica and it is woodgrain
Hey, really nice interior mods, i like the charcaol and the skyline seats...looks real comfy you wouldnt want to get out.
keep up the good work.
thanks, I'm trying to make the interior as modern and comfortable as possible
dash is out being resprayed in charcoal vinyl dye,new wheels and tyres are on,and 84 model 4k hi cam motor motor is going in without all the masses of emmision crap thats on it, just what came with my 3k
Edited by ke30corolla.coupe
the latest addition to my car is now it has 4k hi cam out of a 84 model ke70 and also has been converted to 4 speed manual should go a little better than the original 3k and 2 speed auto more pics as soon as i put shifter in and accessorys on engine
more pics of the manual conversion my interior with manual shifter in and my new 4k motor and 4 speed manual conversion i had to redrill my automatic crossmember to suit the ke70 4 speed manual box,cut the floorpan for the shifter and drill it for the boot and use my automatic tailshaft but no amount of mods to the ke70 pedal box would make it fit so ill have to pick up a ke30 one to complete the conversion so my car now has 84 model ke70 running gear in it I'm stoked
You used an auto tailshaft?
maybe i can use it in my 25.
:wink:
:wink:
yes i used an auto tailshaft out of my ke30 which was a 2 speed auto the spline seemed to fit perfectly and the length was right no modifications needed but keep in mind i havent test driven the car yet due to not having the pedal box but it should be fine. but i wouldnt know if its the same for your ke25 as I'm learning about rollas myself as i go.
Cheers, can anyone confirm that this will work in a KE25
got car running today and the 2 sp auto ke30 tailshaft works fine in my 4 speed manual ke70 gearbox i also used all my 76 model 3k accessorys on my 84 model 4k to totally remove all the pollution crap on the motor.
