February 3, 200719 yr comment_162271 think its about time we had and update and some m\new piccies....or a vid!! :) Report
February 4, 200719 yr comment_162605 Sorrie for asking you all that questions man, but i would just like you to answer these plz Do i need to retard my timing for 7PSI of boost? What is the dizzy? What is the choke flat? show me how to remove it.. Report
February 4, 200719 yr comment_162606 How much boost you running man? Timed it on the 1/4 mile yet? Report
February 5, 200719 yr Author comment_162662 For 7 psi lock ur timing at 20 degrees with no advance at all. Also use NGK B6ES plugs "dizzy" is The distributor. The choke flat is a little plate that is use to richen the fuel mixture when engine is cold. what carby are you using? Ive only driven it once due too a large oil leak :P and only at 6 PSI no 1/4 mile time in my car, but the same setup in Taz_rxs ke55 ran a 16.4 at 130 km/h not sure what psi??? Feel free to ask questions, also talk to Taz_rx he is the Turbo K Series God :D Cheers, Rob Report
February 6, 200719 yr comment_162771 :D far from it, but I'm learning. There is somebody else who is a registered member here who I would refer to as that!! Madrolla68 would be about the only person who know who I mean. :P Report
