November 26, 200619 yr comment_152357 Hi, Was just wanting to find out some information about AE71 brakes. Are they the same as KE70 brakes eg diameter width calipers? As I know KE70 disc brakes and calipers will bolt onto a KE30 with no modifications and then I can use dunnydoor brake pads and have less brake fade and a bigger pad area to increase stopping power by a fraction. As I have a KE30 and want to put the wider disc on the car to decrease brake fade and I am able to get some AE71 brakes and caliper to suit cheap so can anyone tell me if they are a straight bolt on swap for the whole unit? eg there same as KE70 one so they will or did there bolt pattern on the caliper change mount spot etc? Cameron Report
November 26, 200619 yr comment_152361 As far as i know the brakes are the same, Since I'm using corona brakes on my KE70 you can take the KE70 setup if the AE71 setup is different. Report
November 26, 200619 yr comment_152397 Same size disc. 200mm. For some beefy brakes, why not go RA60 celica front struts with KE70 tops? 258mm front disc vs 200mm AND they're vented. :jamie: Edited November 26, 200619 yr by Raven Report
November 26, 200619 yr Author comment_152411 I am wanting to do a AE71/KE70 brake upgrade on the KE30 just so I have less brake fade and so I can use dunnydoor pads and they have a larger surface area on there brakes so a small cheap upgrade as mm I don't think a stock 4K really needs celica vented discs..lol Maybe my 5K if I get one..lol Cameron Edited November 26, 200619 yr by camerondownunder88 Report
November 28, 200619 yr comment_152763 As far as I know, you can still fit Commodore brake pads on the stock calipers, its in the FAQ, was reading it earlier... Report
November 28, 200619 yr comment_152768 mmm interesting I'm doing the ke30 to 70 brake upgrade at the moment and didnt know commodore pads fit ke70 callipers :y: I'm going to keep that in mind for my upgrade :y: Report
November 28, 200619 yr Author comment_152772 yeah dunnydoor pads fit so you can then got some NICE as performance pads to use. Cameron Report
November 28, 200619 yr comment_152774 yeah dunnydoor pads fit so you can then got some NICE as performance pads to use. Cameron cool thats what i was thinking as soon as i found that out Report
