Ke70 In Trinidad,west Indies
ooo right...pressure plate,release bearing,clutch...all of that suppose to come with the gearbox right??...someone on one of my local forums suggested the axles and springs....
  • Replies 54
  • Views 94.9k
Well.... the clutch and flywheel are bolted to the engine so make sure whoever you get the gearbox from includes them as well.
The auto corolla has a different ratio differential (I believe) than the manual to improve economy etc etc but I don't think you will notice the difference with the torque an SR20 makes :) More than likely you will obliterate the diff the first time you side step the clutch... I would be considering an upgrade... I think a T-series would handle SR power if driven sensibly.
thought so about the diff with an SR20.....i read a thread concerning hilux diffs....the older ones are better to use since their ratio varies from 3.5 to 5.3 ( can't remember exact numbers).....
Edited by ca18de in a ke70
i tried finding out what type of diff my ke70 has but to no avail....the owner's manual didnt have it ( or perhaps i overlooked it somewhere)...can someone help me out here??
hey guys gonna install a fuel pressure regulator soon....its supposed to be set at 28psi right??...should i put it a bit higher so that the engine wont lean out or starve for fuel??
took my car for a tune up..not getting it back until tomorrow...the mechanic said he will look into the diff for me....
got back my car and here is what i did:
engine:
changed timing belt
change alternator belt
swapped in NGK platinum tip
tune it
used synthetic oil
sealed a piece of the tappet pan rubber
car:
changed rear shocks to tokico gas
changed front disc pads
changed drum brakes pad
added new brakes fluid
the engine working REALLLY top class now....i love it....
when summer comes i gonna see what next i can do...
  • 4 weeks later...
hey guys...i am just a few weeks from summer break and i have to start looking for a job.....i am gonna do some changes/mods to my ke70 with ca18...This are some ideas :
1) Swapping in a gearbox for the ca18de
2)swapping in a ca18det (depending if my budget allows)
3) swapping in an SR20DE (manual)
I am leaning more towards the 3rd option .....
Fat Bastard has been giving some good info.....
  • 1 year later...
I'm a whole 2 years late to this site and thread lol, i am also from trinidad and i am doing some research as to what needs to be done to fix an S14 SR20DE (VCT) into a Daihatsu Charmant, its my dream project that i would like to start some time this year if my pay allows it, i love the AE86 corolla and the closest thing to it that is available here is the KE70 and the Charmant, was considering placing a 16V 4AGE in but over here the price tag on that and an SR20DE dosent favor the 4AGE in any way, why pay xxxx for a 1.6 when you can pay the same for a 2.0 :( .
Either way would love to get some insight as to suspension work..... intend on replacing bushings with ENERGY SUSPENSION BUSHING KIT replacements.... the engine bay i am not sure as to the complications putting the SR20DE in... thinking i need a stronger rear end, charmant diffs don't do all so well when adding twice the power... so i have heard, thinking RPS13 or SILVIA rear end, how does that sound?
  • 5 years later...
