Raven Posted February 6, 2007 Report Share Posted February 6, 2007 I need to compare my flywheel step in my panel van as I think its possible they gave me too much step, hence the dodgy clutch at the moment. If anyone can measure me the height of the step and get me a picture, that would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
jamesrolla Posted February 7, 2007 Report Share Posted February 7, 2007 ive got one here that i can mesure but what do you want measured?? Quote Link to comment Share on other sites More sharing options...
Redwarf Posted February 7, 2007 Report Share Posted February 7, 2007 Gday Mick, As per our last conversation, I had to space out my clutch cable so that I had enough to play with. It's off a later model Corolla/ Corona/ Toyota?/ Datsun? I can't remember really, but I can pop around to Kelly's tomorrow and pick one up to see if it helps..... Cheers R Quote Link to comment Share on other sites More sharing options...
Raven Posted February 7, 2007 Author Report Share Posted February 7, 2007 That'd be great if you can Rob. ;) jamesrolla: I'll post a pic of my flywheel up. You'll see the area where the friction plate clamps onto the flywheel. Quote Link to comment Share on other sites More sharing options...
OniBerserker Posted February 8, 2007 Report Share Posted February 8, 2007 hey man I dug up my 4k flywheel measured with steel ruler, step is 1mm or 1.5mm pretty sure its 1.5 but mines dirty Quote Link to comment Share on other sites More sharing options...
Raven Posted February 11, 2007 Author Report Share Posted February 11, 2007 Cheers OniBerserker. I think mine's a little bit bigger than that from memory. Will find out this coming weekend when the gearbox comes out again *sigh*. Starting to become an expert haha. Quote Link to comment Share on other sites More sharing options...
styler Posted February 14, 2007 Report Share Posted February 14, 2007 hey if you look on the xtremeclutch or daiken/exedy website it lists the flywheel step height for their clutch kits. Quote Link to comment Share on other sites More sharing options...
Raven Posted February 23, 2007 Author Report Share Posted February 23, 2007 Just had a look at the Exedy website, and it says the Flywheel profile should be 1mm. Me thinks they screwed up when machining. Just gotta find some time to pull that gearbox out... Quote Link to comment Share on other sites More sharing options...
