mozzy Posted February 23, 2007 Report Share Posted February 23, 2007 hey i have a 4age 16 vaulve and a ae71 and I'm putting them together next weekend so i need some info on fuel set up i just want the thing to be able to run i don't want some flash million dollar set up so whats the baisic go for this convertion thanks moz Quote Link to comment Share on other sites More sharing options...
Jono Posted February 23, 2007 Report Share Posted February 23, 2007 you will probably need either a surge tank setup or transplant an EFI tank/pump setup from another car. i used a high flow/low pressure lift pump to fill a surge tank and then a high pressure EFI pump (bosch 070). Quote Link to comment Share on other sites More sharing options...
mozzy Posted February 24, 2007 Author Report Share Posted February 24, 2007 how much roughly am i looking at for a fuel set up like your one, i was just under the impression i just needed a more poerful fuel pump. thanks Quote Link to comment Share on other sites More sharing options...
Jason Posted February 24, 2007 Report Share Posted February 24, 2007 you don't need some super high pressure pump (as the 4age has the rising rate regulator any way). You don't really need a surge tank, but i suppose its a nice peice of mind. Surge tank you can get for about $100, fuel pumps range from $80 upwards new. I have used the classic VL pump and a VL lifer to pump into a 1.7L surge tank. My setup cost me over $200 all new pumps and surge tank, plus all the little things like rubber hoses clams ect Quote Link to comment Share on other sites More sharing options...
mozzy Posted February 24, 2007 Author Report Share Posted February 24, 2007 yeh i like the surge tank set up but its all money i don't have, baisicly i just want this motor to run and maby one day ill get a surge tank set up.. how do i avoid the surge tank set up???? also where did u get ur surge tank setup from and if you have and pasiffic brands or anything like that.. thanks mate mozzy Quote Link to comment Share on other sites More sharing options...
Raven Posted February 24, 2007 Report Share Posted February 24, 2007 Your standard fuel tank isnt baffled so the fuel will run away from the lift hose if you don't have a surge tank. You'd have to keep it above 1/4 of a tank of fuel otherwise if you corner hard, it will kill your one and only fuel pump. Research dude. This has been covered many many times before, not only on here, but on AE86DC and Toymods. Quote Link to comment Share on other sites More sharing options...
mozzy Posted February 24, 2007 Author Report Share Posted February 24, 2007 thats all i needed to here. surge tank it is thanks guys Quote Link to comment Share on other sites More sharing options...
Kebin[RL] Posted February 24, 2007 Report Share Posted February 24, 2007 ebay usually has some surge tank bargains i got mine off there Quote Link to comment Share on other sites More sharing options...
Jason Posted February 24, 2007 Report Share Posted February 24, 2007 same :) You carnt really get a dud surge tank unless somes just glues the connections in Quote Link to comment Share on other sites More sharing options...
Robert Posted February 24, 2007 Report Share Posted February 24, 2007 A mate of mine said he bought a cheap one, and it was sitting with a little bit of fuel in it and it exploded :) . Quote Link to comment Share on other sites More sharing options...
mozzy Posted February 25, 2007 Author Report Share Posted February 25, 2007 yeh my mate showed me these i think ill get one of these there loonking nice... its worth the extra $$$ and its still fair cheap hope you like http://classicford.mine.nu/forum/topic.asp...erms=surge,tank check the link Quote Link to comment Share on other sites More sharing options...
