corolla-ute Posted May 3, 2007 Author Report Share Posted May 3, 2007 Drill 2 holes in the xmember, extend the shifter hole, lengthen the reversing light wiring and it should be all good. :jamie: problem with that felix is that i think the handbrake will be in the way of the shifter, maybe it will have to be moved...... if you look closely you will see handbrake alongside driver seat....(opinion please) Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted May 3, 2007 Report Share Posted May 3, 2007 (edited) 90% sure the shifter will end up half way between were it is now and the handbrake. Since you have both a ke70 and ke30 box, measure from the front of the bell housing to the centre of the shifter hole on each. The difference will be the distance it moves back. :jamie: looking at this pic it only seems to be 2 inches max!! Edited May 3, 2007 by Taz_Rx Quote Link to comment Share on other sites More sharing options...
corolla-ute Posted May 3, 2007 Author Report Share Posted May 3, 2007 90% sure the shifter will end up half way between were it is now and the handbrake. Since you have both a ke70 and ke30 box, measure from the front of the bell housing to the centre of the shifter hole on each. The difference will be the distance it moves back. :jamie: looking at this pic it only seems to be 2 inches max!! thanks for that i'm sure i measured b/4 come to think of it ....ok 5 speed going in soon..... thanks for the help :y: Quote Link to comment Share on other sites More sharing options...
Felix Posted May 3, 2007 Report Share Posted May 3, 2007 Alot of people have said that , but they are only 14 inch....... So... You can still get decent performance tyres in 14's. It is your car though, do what makes you happy. :jamie: I reckon you should be fine with handbrake clearance. As Taz_Rx said, measure it up. You will probably find the shifter will be in a more comfortable position with the 70 box. Quote Link to comment Share on other sites More sharing options...
Mickoolz Posted May 3, 2007 Report Share Posted May 3, 2007 Love the ute dude. :S I didn't even know they existed untill now! I sold a panelvan to a friend and he planned on cuttin n shut it to make his own rolla ute. Not too sure if he still is tho. :hmm: Anywayz tidy ride! good work Quote Link to comment Share on other sites More sharing options...
