Ae80 Wheel Pcd
just need some help in the way of stud pcd for an ae80 rolla and what would be the bigest size wheel i could fit with out doin any work?? i looked through the website but couldnt really find any thing cheers Tory
I have 15s on mine with 195/50 tyres.
Fronts are great - backs have nice scrub marks on the outside from the guard lip (but only when there are big guys in the back)
You could also drop into a couple of the tire shops and grab some of the catalogues. Most times they'll say what the pcd is as well as the centre hole.
Hey thanks guys the help is good! I'm looking at a set of 16's do u think that they mite be a tad big?? in reggards to the pplz in the back thats ok i never have any one in the back :> Once again thanks for the help!
16's should be fine, but in saying that you should check the off set of the wheels as well which should be +38 to +45.
if your worried bout the rears scrubbing you should also think bout getting the lip on the rear guards rolled
16s are a good choice because they allow for some decent tyre profile and fill out the guards really good where as 15s looks too small on some cars and the only tyres in a 17 are rubber band thickness, I cringe every time some one comes to work with 205/40x17 or worse 215/35x18. Also ill state that 215/35x19 will fit under the guards of ae82 sedans with a bit of body refinement but not as much as u would expect. First hand exp. Lol
