Ke70 Suspension And Steering
i put the beloved ke70 into the gutter and was just wondering what other model corollas have the same suspension and steering as the ke70 so i can look wider than ke70 spare parts.. cheers
Ae71.
Ke70's are easy as to find.
sigma lcas, when u finish putting them in dw, your wheels arent bent
What is bent?
the right hand lower control arm, possibly the sway bar and the other rod lol not sure what its called but its only right hand side
Edited by Greene
castor rod.
yeah ae71, t-18 (have to cut off the lock stops) ae86..... corona lca's fit, they are slightly longer and will give you about 2 degrees of camber..
but ke70 are a dime a dossen
