Nt Major Discussion
look like i can use the e6 and still hav launch conrtrol and shit hahah anti lag i must use that!!!!!!!! the 6 and 8 both seem the same doe sit matter which one????????? and are they plug and play or u hav to wire them up?????????
  • Replies 3.4k
  • Views 289.8k
As far as I know they take the place of the stock ecu, of course a little wiring up would be needed, NO WHERE near as much as a microtech though.
Not sure about the differences.
Antilag is for turbo's you wanker :)
U nooB i know its for turbos thats y i said i should use it
wouldnt mind the launch control thou then i can back fire n shoot flames
New plate
FLMTRWR
or
SPTFIRE
:D
Edited by wasfishing
True that. :)
Been recommend a few places up here. Winnelie Performance(cobraed from boost) for the balance. JNL crankshafts for rebuild. and hi-tech for everything else :D
I want to do a dodgy number plate application one day lol. something like OII YOU OVER THERE WANNA RACE?
one day I will get that number plate, cover the whole rear bumper :).
Adam, you able to PM/email me for a list as descriptive as possible as to the parts I would need for a turbo build
thanks babe, you owe me, for the numberplate shit again/bottlecaps still in my car
And you'd still get lagged by the KE55. :P 9,000rpm FTW!!!
The same ke55 that hasnt moved under its own power in a least a month :)
Not gunna happen adam :D :P
A month? It's WAY more than that!!! It hasn't moved (at all) since the 22nd of July.
Just you wait till it is moving again. When it is moving, it'll REALLY move. I want to crack a 1:30 at Hidden Valley next time I take it out. :P
You misunderstood, I just need a list of parts NOT SPECIFIC parts
like turbo
manifold
plenum
ecu etc
I got a grip on most of it, just trying to get an idea of all small things etc
GET BOTTLE CAPS OUT OF MY CAR
Turbo
Inlet manifold/plenum
Intercooler & piping
Exhaust manifold
ECU
Thick head gasket (1.6 or 2.0mm) or 4A-GZE pistons or after-market low compression forged pistons
That's all I can think of off the top of my head. There is more you can do, but it's not essential (eg. injectors, fuel return line, etc).
If I was to use forged Arias Pistons for the 20V drops compression to about 9:1, what sort of head gasket to use? metal for sure eh?
Yeah, I'd use a metal head gasket, but you could use a 1.0mm thick one as you wouldn't want to drop the compression any further. You'd need the metal gasket to avoid blowing the gasket out from the boost.
Any recomendations?
For reliability what else would you recommend for when the motor is rebuilt?
