Hey guys , i just had a silvertop engine installed in my ae92 and was wondering if you guys could help me out. when the car is warmed up and after driving it hard for a short period it starts to have a constant ticking noise which speeds up and slows down with the revs, should i be worried? and if so what can i do? Any help would be greatly appreciated. thanks
Thanks soooo much :y: i was really getting paranoid about it because i've only had the engine in for about two weeks, should i replace the cam pulley or the solenoid?
Both if you can, but its usually just the pulley. Not cheap and very had to find in Australia. It usually doesnt effect performance at all when the pulley atarts ticking. Its a 100,000klm service item I believe, and its usually really noisy by then, so if its loud it can be a good guide as to the klms on your motor.
Thanks little red spirit :y: , that makes sense because the engine had about 80,000kms on it before it went in and we changed the timing belt seals and water pump i didn't even think to change the pulleys do you know where i may be able to find a solenoid because i can get toda cam pulleys if they would be a good upgrade
Thanks guys :) , i was talking to the guy that installed it and he said that there is a seal on the back of the original pulley, does anyone know about this? if i get toda cam pulleys would i need to disconnect the vvt
hey how much did the conversion cost you??
coz I'm also looking at a 7AFE setup for my AE92
