November 11, 200718 yr comment_208626 I'm new here, so HEY there! :) Anyway, down to business. I should be picking up a ke30 with a 5k in it in the next few days, I'm tossing up whether to take it out and put it into my ke55 cause the shells a better colour and its my original car, but thats another story, what i need to ask is, the 5k has dual 40mm webbers fitted, but both are in need of service, does anyone know how much I'm looking at to get these serviced? is there anyone here with a 5k in a ke corolla? thanks guys! Report
November 11, 200718 yr comment_208640 hey dude, welcome to rollaclub! firstly, deciding what shell to put the motor in should be governed by a corollas worst enemy... rust. if you let us know where abouts your from I'm sure someone can direct you to a good place. i know personally if your in sydney, parramatta carb services is good. also most people on this site have or hav had 5k corollas is a pretty common conversion so please don't hesitate to ask if you have any other questions :) Report
November 11, 200718 yr comment_208656 also remember 55s are heavier except for mine as it cancelld out the extra weight with rust holes Report
November 11, 200718 yr Author comment_208657 Thanks for the replies guys, my shell has next to no rust, none that i can find anyway? and the ke30 has minimal according to the guy (I'm not going to see it till tuesday night) how much would i be looking at per carby to get them through a rebuild? anyone got any idea? Another question, the engine is setup like this- Dual 40mm sidedraught webers electronic dizzy fully balanced duralite pistons extractors full exhaust over-sized radiator i think thats all plus it has heavy duty springs 14" hotwires and its a 5 speed I'm picking it up for around 1750, its in a ke30 at the moment and it comes with a spare 5k and 5 speed box. The carbies need rebuild and the engine needs a big service, like fluids flushed etc. Exhaust/inlet manifold gasket needs replacing, does this sound like a good deal? how do you reckon the engine should go? Thanks for your replies!! Nathan. Report
November 15, 200718 yr Author comment_209360 I'm sorry to bump this, but I'm running out of time to decide, with the minimal technical knowledge that i have myself i need some advice from anyone that knows what they're talking about, is this deal worth it? I had a look on tuesday night but times running out and i need to let the guy know so i can put a deposit on it, thanks heaps to anyone that can help me out. nathan. Report
November 15, 200718 yr comment_209364 so you'll be paying $1750 for a ke30 with a 5k and 5spd box. and getting a spare 5k and another 5spd box? does it come with rwc/rego? i paid $300 for a ke35 with a rooted body, 5k and 5spd, extractors, exhaust, and no rego. i'd probably want to get him down to around $1300-$1500, but then, i can't haggle at all :hmm: as for rebuilding the carbies, give a few calls to places that do rebuilds...they'd be able to give you answers and prices :lolcry: Edited November 15, 200718 yr by dfunkt Report
November 15, 200718 yr comment_209366 Mate for $1750 it not a bad buy. here's a quick run down if you were to buy all this stuff as seperate parts: Car itself, if no rust <$500 Rebuilt 5k with new pistons balanced crank etc <$500 twin WEBERS (not delortos or solexs!) <$500 Electronic Dizzy $150 Extractors $200 Exhaust $150 Modded radiator <$100 Springs $100 Hot wires $200 5 speed $150 Spare 5k (provided its still in good condition) $200 Spare 5 speed $150 So even if you were to buy it and wreck it at these prices (which I don't think are un-reasonable) then there is nearly $3000 worth of parts!!! Does that help!!? :lolcry: :hmm: Report
November 15, 200718 yr Author comment_209368 haha thanks taz that did kinda help actually :lolcry: Another question, would anyone care to estimate about what kinda power output this would have? or what i'd expecting to be on par with speed wise? that isnt a huge concern to me, another thing, the guy said that the compression of the engine when he had it running was 190psi like 11:1 isn't that really high? Like i said my knowledge is quite minimal, thanks dfunkt and taz for replying, i appreciate it heaps. Report
November 15, 200718 yr comment_209369 Engine compression - 190psi and the CR - 11:1 are 2 different things. CR is worked out by volume at (Bottom dead centre) devided by volume BDC TDC (top dead centre). For example if 1 cylinder @ BDC holds 110cc and then at TDC its capacity is 10cc.....110/10=11 ie, 11:1 CR :lolcry: This never changes. 11:1 is getting up there, but not stupidly high. You wouldn't put a turbo or SC on this motor. Engine compression basically just tells you how good your piston rings and valve seals etc are. The more they leak, the lower the compression will go. Oh and 190psi is pretty good! Power for that setup would be around 50rwkw. Report
November 15, 200718 yr Author comment_209376 Oh thanks for clearing that up. Feel like a bit of a noob, but if i don't ask, i don't know, and you gotta start somewhere. Is that 50rwkw at the wheels? or at the fly? thanks again for replies, its alot of help. Report
November 15, 200718 yr Author comment_209379 haha sorry, i warned i was a noob. Alright well i have to wait and see what happens now, hopefully picking it up on sunday, it'll be a while before its running though, with carbies to reco, gaskets to replace and oils fluids and filters and the rest to be changed, but i can't wait :lolcry: Report
November 15, 200718 yr comment_209521 haha sorry, i warned i was a noob. The more you haunt the forums the intelligence you'll gain :lolcry: :hmm: Report
November 16, 200718 yr Author comment_209715 thanks again guys. I do appreciate your replies, and your patience :lolcry: I'll be SURE to post pics every step of the way, for now, heres my current one.. Edited November 16, 200718 yr by KE555k Report
