Removing The Head
hey i have a 2TG and I'm currently in the proces of taking the head of the car.
i have taken the cams out and have un done all the head bolts but it still wont come off.
there are to bolts in between the plug holes but I'm not sure if un doing these will remove the head.
Does any one know?
thanks sam
the head gasket will be sticky, you have to lever it off on an appropriate section with a pry bar or pinch bar etc
Does any one know?
thanks sam
you could put the plugs back in and crank it over let the cylinder compression do the hard work for you.
its all good now guys got it off just a bit of leverage did the trick, and when it came there was a broken valve sitting on the top of the piston :lolcry: thanks for the help anyway.
is there any bolts around the front of the engine, by the timing cover where it meets the cylinder head.
hit it with a hammer! :lolcry:
  • 4 weeks later...
thread reseructed for that post alone ^^^^^^^^^^ haha
the bigger the problem the bigger tha hammer
:P :D
