April 1, 200818 yr comment_236696 hi all rolla fans. i was just wondering what sort of power people were making without fully seam welding there rolla. and also what sort of braking system they are running, i am running vt ss commodore brakes on front and 9inch drum rear. Report
April 1, 200818 yr comment_236702 hi all rolla fans. i was just wondering what sort of power people were making without fully seam welding there rolla. and also what sort of braking system they are running, i am running vt ss commodore brakes on front and 9inch drum rear. I'm currently running standard brakes allround on my KE20's :nervous: and would like to hear some suggestions aswell........... Anything would stop better than my current setup, i reckon.... Was previously considering (Front) KE55 Hubs, RA40 Celica Rotors and Calipers (Rear) KE55 Diff Which would also give me a wider choice of Mags and....future brake upgrades Report
April 1, 200818 yr comment_236704 Power doesn't really have any relation to why you seam weld a car. You seam weld it to make the chassi more rigid so it doesn't flex. Can improve your handling quite a bit.. Report
April 1, 200818 yr comment_236738 if you have enough power (and grip) you can twist the whole car :nervous: ill being running somehere in the region of 180-200rwkws I havent looked into brakes/suspension yet as I'm not up tp that stage of the build, but will be very shortly so ill be keeping an eye on this thread. I plan on running coilovers in the front with atleast 4 pot 280mm brakes and a disk brake rearend when the diff conversion gets done. Report
April 1, 200818 yr comment_236757 i was told by the tuner i should expect 140 - 150rwkw. i'm still using the ke55 discs/calipers and the ke55 diff. i will upgrade the fronts first and then change to a w5x box and do a diff conversion (still undecided, but probably vn v8 borg warner), might even use the commodore stud pattern. Edited April 1, 200818 yr by Jono Report
April 2, 200818 yr comment_236951 that sort of power should be alright, depending what sorta tyres your looking at running, but at the end of the day, if your putting a bit of work into the chassis why not make sure it isnt gonna pull apart. my ke70 did and its irritating coz you more or less have to go to a new chassis, or use the old one and get it checked for true and repaired... cheers, andrew Report
