May 31, 200818 yr comment_249898 is the standard KE 4 speed gearbox input shaft the same as the 5 speed input shaft? The boxes look the same but not sure Report
May 31, 200818 yr comment_249904 is the standard KE 4 speed gearbox input shaft the same as the 5 speed input shaft? The boxes look the same but not sure I don't think so (I have been wrong before) I bought 2x clutches one for a 4sp and one for 5sp k boxes and one has a bigger input shaft than the other. Cheers. Report
May 31, 200818 yr comment_249911 Some K50 gearboxes come with a 19 spline input shaft and some with a 21 spline and the K40 is a 19 spline Report
June 1, 200818 yr comment_250068 As far as I'm concerned they only ever came with a 19 spline input shaft. The reason ripco etc list a 21 spline gearbox is for the T50. Report
June 1, 200818 yr comment_250080 As far as I'm concerned they only ever came with a 19 spline input shaft. The reason ripco etc list a 21 spline gearbox is for the T50. I concur 100%!! :bash: Report
