hey everyone
I'm looking at laithing both my primary and seacondary venturis.
The engine I have is a 3K-C and I belive that the standered venturis are, 21/24 mm
What would be the largest size you would recomened, the take them out to, it is only a 1200cc!
any help would be appreciated.
cheers Sam.
hey everyone
cheers Sam.
don't bother,it will upset the flow of the carby,if you want greater flow buy a larger carb.
Sounds like nonsense but bigger venturis will give less performance. Venturis are designed to accelerate the airflow through the carb. The acceleration creates a pressure drop that pulls the fuel from the bowl.
Larger venturis = less pressure drop = less fuel pulled out of the bowl. You may be able to improve on it, but it may just as easily got pear shaped without a bit more diggin.
  • 3 months later...
Hey guys a bit of an old topic but i recenlty replaced my seacondary venturi and i have noticed some increase in the power when its working, also gives a deeper induction noise.
and you can't machine them... there too poris, i've tryed, theres bigger ones out there my turbo carb has 24/29 (if i remember right) but you can't really go bigger than that, my secondary isnt really much of a venturi, but its only there for boost so it doesnt matter to me lol
