Pinging 4k
a mate and i just put in a elec 4k dizzy in his ke70, as far as i know we installed it right and seems to run ok but it pings its but off! even when i adjust the timing as far as i can both ways (the slot in the dizzy limits how far i can rotate it) it still does it, and when we do get it to almost stop pinging its slugish as all hell!!
whats going on???
what he said, take it out n put it back in the other way round ;)
you could also have it a few teeth out.. you really need a timing light to dude.
No teeth on a K series dizzy, its got a tongue and groove drive. Only 2 ways it'll go in.
Ummm what, No it don't and you can put a screwdriver into the oil pump and turn it to suit the dizzy.
Thats an oxymoron!
Anyway, you might have got your dizzy in 180 degrees out of whack which would cause all sorts of issues.
If the dizzy is 180 degrees out, the spark plugs, spark on the fuel in stroke. right? ie: car will not start, ever.
Chirs
it may actually be sparking properly and burning the fuel, are you sure it didnt ping before?
my 4k would ping with standard timing on regular.
Use a timimg light and try running it on premium unleaded that will stop the pinging aswell
yeh no shit, brain fade, thats the oil pump drive. :D
12 hour days. Wrong tooth on the dizzy.
Last dizzy brainfade I had, I plugged all the leads on my 911 in reverse order (these german engineers are so good, they don't bother labelling the dizzy caps)
so instead of firing
123456
I had
165432
and the thing ran but wouldnt rev..... pretty funny.
Edited by philbey
its working ok now, it wasnt 180 deg out just a tooth out (which i thought couldn't happen)
thanks :D
