hey trying to suss out all the ke corolla factory wheel specs,
have got various specs off the net and off tyre shops databases
but they seem to vary a bit and we may have to take wheels
off our cars and measure them to get the real deal.
the reason for this is that it would be useful to know as the legally specs
can be only changed by a certain amount and also going too far interferes
with clearance and turning as well as handling.
a list to do so far:
ke10
ke11
ke15
ke17
ke20
ke25
ke30
ke55
ke70
1983 KE70: 13x4.5 32mm offset. Tyres I had on them were 175/70, but I'm not sure if they're the standard size.
Edit: These specs were printed on the 'lip' of the wheel. Not measured up by myself. :D
Edited by adam-__-
4.5" sounds about right. KE30's came with 13x4.5" rims standard and ke70's have the same rims. The KE70's with the CSX alloys may be a little wider (possibly 5"?).
KE10's have 12x4" rims standard. No idea on the offset.
In the Motor Vehicle Modifications booklet on the QLD RTA website it states that you can only run tyres 1.3 times wider than the manufacturers widest optional tyre. So for a KE35 which has 155's listed in the owners manual you would be limited to 195's legally. The booklet doesn't state anything about rim width, but says you can run larger diameter rims, so long as the tyre diameter varies by less than +15mm or -26mm. Also wheel track can vary by up to a max of 26mm
cheers felix, will add that modification info. soon all states will be under ncop (starting next year?)
and i think those modification limits are the same as the qld motor vehicle modifications stated there.
ke25 stock rim are 12x4, will measure up offset sometime
Edited by styler
