ROLLN'03 Posted March 30, 2005 Report Share Posted March 30, 2005 I was ponderin as we all do from time to time? Can you turbo charge a 5k? Ive seen pix of them but no real info? ANY THOUGHTS??? :D JK Quote Link to comment Share on other sites More sharing options...
NickZ Posted March 30, 2005 Report Share Posted March 30, 2005 This is a question that has been ask thousands of times.....SEARCH. But yes you can turbo ANYTHING. The real question is "is it worth it". If you are skilled enough go for it, Id rather supercharge it. 4agze sc12 would do the job nice and there is no need to make exhaust manifolds etc. easy as bolt it on(well fab some brackets,air pipes,pully), you can either use draw through or blow through carb setup. You could run 6 psi boost into a standard engine without too much modification, That would give you a nice power gain. Quote Link to comment Share on other sites More sharing options...
ROLLN'03 Posted March 30, 2005 Author Report Share Posted March 30, 2005 TELL ME MORE!!! I got a mate whose got a mate whose selling a sc14 supercharger and intercoller for $300 bucks. Locally. I'm buying the 5k this weekend, got $1500 to spend, what you think ? ANy help would rock ... thanks Quote Link to comment Share on other sites More sharing options...
NickZ Posted March 30, 2005 Report Share Posted March 30, 2005 (edited) yeah get the supercharger. nice thing about that is no need to make manifolds,no oil lines,no water lines,no exhaust modifications but a set of extractors and a 2" systen will be fine. stick it on the driverside (youll have to fit it upsidedown, youll understand why when you do it) of the engine, stick on a side draft webber on the inlet side, run the shortest pipe you can to the standard inlet manifold removing the carby bolt to where it was, find a aircon or make something for the crank shaft pully for the extra belt and a VN-VP ilder wheel (tightens the fan belt by applying pressure on it, your using a vn-vp coz they run flat belt so you can use it on the top side of the fan belt) if ya get one with a electric clutch wire it to a positive ignition on. thats it....go BOOSTIN Edited March 30, 2005 by NickZ Quote Link to comment Share on other sites More sharing options...
Xany Posted March 30, 2005 Report Share Posted March 30, 2005 lovely..... however.....talk to an engineer first.....you don't wanna do something you may regret later. Quote Link to comment Share on other sites More sharing options...
Teddy Posted March 30, 2005 Report Share Posted March 30, 2005 Pfft been there done that. Its when you start drifting the oil drums at work when you start to think...hymmm..... :D Quote Link to comment Share on other sites More sharing options...
Xany Posted March 30, 2005 Report Share Posted March 30, 2005 damn you guys crack me up.... BWAHAHAHAHAHA! DRIFTO! Quote Link to comment Share on other sites More sharing options...
rjenman Posted March 30, 2005 Report Share Posted March 30, 2005 lol @ drift pussy Quote Link to comment Share on other sites More sharing options...
