March 31, 200521 yr comment_37325 A lot of you will probably have already heard of or visited this site, but I thought I'd give it a mention anyway. It's about Toystar, a Mark 1 (AW11) MR2 with a 4.6L Cadillac Northstar V8 being dropped in. Don't ask me at what point it went from just having a V8 dropped in, to having a turbo'd V8 being dropped in, just enjoy the madness. The address is: www.v8mr2.com Report
April 1, 200521 yr Author comment_37492 Now someone needs to invest HUGE amounts of money in doing a pure Toyota version. AW11 + 1UZ-FE/3UZ-FE = Awesome!!! Report
April 1, 200521 yr comment_37496 I think someone was looking into a 2jzgte conversion. Unsure on the 1uzfe conversion though. Report
April 1, 200521 yr Author comment_37498 The 2JZ-GTE conversion would be interesting, though I wouldn't have thought that it would fit. I know that the reason the guy doing Toystar chose the Caddy V8 was because it was available with the FWD transmission, so all he (basically) had to do was squeeze it into the MR2. One option might be to use the 3.3L V6 from the Toyota Kluger. It's not that powerful, but I think it's positioned tranversely, which works for an MR vehicle. Or you could be boring and use the Camry V6. :dry: Report
April 1, 200521 yr comment_37545 http://www.v8mr2.com/images/day101/images/P2270687.jpg my god that guy has a death wish...BUCHERED!! Report
April 2, 200521 yr comment_37572 Last time i went in one of them it was sick to do dounuts in. Imagine the G's that weapon would have spinning around. Report
April 4, 200521 yr Author comment_38086 He claims to know all there is to know about AW11's, so he must be right. NOT!!!!!!!!!!!!! Report
April 4, 200521 yr comment_38140 I'll tell ya right now that the front suspension is gonna be all out of geometry...thats if it doesnt fall apart.... Report
April 4, 200521 yr Author comment_38180 perfect car to fit 2 engines to. Yeah, if you're prepared to completely savage the car, basically destroying anything the manufacturer installed. Plus, it would have to lose it's handling ability, as it'd have WAYYY more weight at the back than at the front, probably something like 30:70 front-to-rear weight distribution, so steering would be interesting. Of course, the guy does talk about dragging it, and it should be pretty good for that with the weight over the rear wheels as they are. Report
April 8, 200521 yr comment_38628 yep... the front end is being completely redone using a pre-made indycar style suspension / subframe made by a well know hotrod maker here in the US. The shocks will be in the frunk, so no more struts. The rear is also being done by another shop. A custom aluminum sub-frame is being built with the proper suspension geometry. I have never claimed to be a fabricator, as noted by your post about my rear suspension. And I was never happy with it. I know where my weaknesses are and where I should stay away from playing :D The goal of the car is to actually go 200mph. Now I have taken a break from the car. I am having to save up my cash for the front and rear... which is going to cost over us$6000. But in the end it will be safer and actually work. Now until then I am building another car, a MK1.5, 350hp 2 liiter 3sgte. This is where i am as of last night... just have one more mount to make, and then I can put the real engine in (the one fitted is an empty 3sge for test purposes, easier to move an empty engine than a fully prepped one) http://www.racingstrong.com/RSGT/day1/index.htm http://www.racingstrong.com/RSGT/day2/index.htm http://www.racingstrong.com/RSGT/day3/index.htm http://www.racingstrong.com/RSGT/day4/index.htm http://www.racingstrong.com/RSGT/day5/index.htm http://www.racingstrong.com/RSGT/day6/index.htm http://www.racingstrong.com/RSGT/day7/index.htm http://www.racingstrong.com/RSGT/day8/index.htm http://www.racingstrong.com/RSGT/day9/index.htm Edited April 8, 200521 yr by Bill Strong Report
April 8, 200521 yr comment_38632 and here is the car that 2.0 turbo is going into. Powered by a ATS CT27 turbo, TED Components 264 cams and lots of other normal boltons.. hp is expected to be close to 300rwhp. The car is a lightened 1986 aw11. ST165 front brakes, and I am going to try and fit ST165 rears on as well. Report
April 8, 200521 yr comment_38636 hmmmm that would be fast..... very cool Bill, how do those "ct27s" compare to a steel "ct20b" iv heard conflicting reports. as for fitting 2 engines as someone mentioned above, whats wrong with that? itd be a mission, but i like mad cars :D iv always wanted an aw11..... but id go 20v turbo, or maybe 7agte 20v.... :blinks: oh welcome aboard bill :dance: Report
