December 12, 200817 yr comment_297284 Not sure if this is allowed, but thought i'll give it a go. Any questions related to your projects that you want to ask, goes here. Instead of the other topic being flooded by general and tech questions altogether... Will be very strict in here, so please, only tech questions only, all other stuff goes to the other topic. If possible, will trial a template to see how it goes, and also makes searching through the topic alot easier. Car: (eg. AE92, KE70, TA22) Engine: (eg. 4AGE, 4AC, 4AGZE, 3SGTE) Section: (eg. Engine, Brakes, Suspension, Wheels, Interior) Question/Problem: (eg. Can i fit item A to my car?) Thanks, Daven :) Edited December 12, 200817 yr by Sirolla Report
December 12, 200817 yr comment_297377 ill start it off shall i swapped sc14's today now shes running like a speedway car all ruff n shit :) any ideas I'm thinkin maybe air leak Report
December 13, 200817 yr comment_297617 Sweet as, was just thinking about this. Good idea Daven. Try the Inox/WD40 spray thing for air leaks birdman, see how you go. I'm making progress... Motor is in and fuel system done (bar wiring the pumps) but now I'm up to wiring the motor in and to be honest I have no f@$ken idea where to start, not even sure if the loom/ecu combinations I have will work. Tis a real headf@$k. Going to take planning but not really sure how to start... Would be good if my supposed AE82 ECU matched part numbers with the rest of em! Does anyone else have access to an AE82 4AGE ECU so I can check the difference? EDIT: Just rememebred that you've got that AE82 Adam. Could I pinch a few bits off that possibly? or at least come and look at it if these people across the road don't let me snoop around their Twincam hatch. Edited December 13, 200817 yr by Killswitch Report
December 14, 200817 yr comment_297733 I only had the AE82 for about two weeks and we ripped the engine out of it pretty quickly. I've still got the AE82 4A-GE ECU though and you're welcome to compare it to yours (or even better, buy it :jamie:). As for my projects, we got the GT-Four running again yesterday. Once my financial situation is sorted out, I plan on getting the oil line issue fixed, cleaning the engine bay, and getting it re-registered. Will then take it to L&S or somewhere for new suspension bushes, then get some new 235/45 tyres on the Wedsport rims with a full wheel alignment, and probably into Toyota after that for a full service. Report
December 14, 200817 yr comment_297781 I only had the AE82 for about two weeks and we ripped the engine out of it pretty quickly. I've still got the AE82 4A-GE ECU though and you're welcome to compare it to yours (or even better, buy it :jamie:). As for my projects, we got the GT-Four running again yesterday. Once my financial situation is sorted out, I plan on getting the oil line issue fixed, cleaning the engine bay, and getting it re-registered. Will then take it to L&S or somewhere for new suspension bushes, then get some new 235/45 tyres on the Wedsport rims with a full wheel alignment, and probably into Toyota after that for a full service. Did you get the MAP sensor? How about igniter? Report
December 14, 200817 yr comment_297906 Try the Inox/WD40 spray thing for air leaks birdman, see how you go. that didnt work last time danno and they didnt seem to be very flamable.... Edited December 14, 200817 yr by Sirolla Report
December 14, 200817 yr comment_298041 Did you get the MAP sensor? How about igniter? Got the whole freakin' engine. MAP sensor, igniter, everything. I want it gone - $100 for the whole lot. $20 for everything except the head if you disassemble it for me. Edited December 14, 200817 yr by ancullen Report
December 15, 200817 yr comment_298128 Got the whole freakin' engine. MAP sensor, igniter, everything. I want it gone - $100 for the whole lot. $20 for everything except the head if you disassemble it for me. Shall get back to you Adam. Willing to separate Dizzy from the head? Report
December 29, 200817 yr comment_302519 Car: 1989 nissan silvia engine: CA powah baby + 20psi Problem: the tread seems to disappear off the tyres at an alarming rate, with the amount i get pulled over this is worrying... any one got any suggestions? seriously though. i DO have a blown head gasket, also have an entire CA18 in good nick with no blown gasket, want to swap motors but alas! no where decent to work on the car.... anyone want to rent their shed or carport for a weekend? Also have me a AE71 with no motor lol need to get a 4AC if anyone knows where i can get one see guys i feel the rolla love still ;) Report
December 31, 200817 yr comment_303096 righto i has an engine... anyone up for helping put it in on sat arvo and sunday? will put on beers and a good feed for those lending a hand :) mostly just need help with the little jobs that require 2 people at once Edited December 31, 200817 yr by Ella Report
January 12, 200917 yr comment_306973 My new little project for the Levin is chopping up some aluminium sheet to make a shroud/cover to fit between the radiator support and grill. If it looks ok, will polish it to suit the rest of the engine bay :y: Report
January 12, 200917 yr comment_307065 you mod will be to drive your car you mean like inbetween the turbo and the rad? Report
January 12, 200917 yr comment_307168 not 100% sure yet will be doing between grill and radiator but might extend it a little over the back to act as a heat shield between rad and turbo possibly drove the car yesterday arvo tis fun :y: fullnoise made some skater kid fall off his ute haha Report
January 30, 200917 yr comment_312780 hrmm well i know I'm not there anymore but this sections kinda dead yo Car: KE70 corolla sedan :y: Problem: has a "hot 5k motor" when i went to look at it i got the guy to run it... had a serious sound inside the head. Fixor: well i just pulled the head and manifolds off in an hour (little bit eager lol).... found the last rocker had no retainer and had fallen off, the knocking noise must have been something to do with that, though everything seems to be in order man if it wasnt oily you could eat off the inside of this motor... everythings brand new including bigger valves, better valve springs and recoed head... Will turn it over tomorrow and listen to the bottom end to be safe then its all going back together and off for rego :P let yous i know how i goes y'all Report
October 22, 201214 yr comment_633059 just bought an AE82 seca twin cam for 150 bucks running nicely as a donner for my AE71, guess thats where I'm at for the moment Report
