hey all,
i have a next to standard 4k-c with extractors and 32/36! it has breaths so much oil out of the rocker cover breather....
My catch can ends up being half full after every race meeting? So i thought screwed pistons rings coursed this, so i did a compression test and it has 150-155 in all 4 cylinders!! What else courses blowby?
cheers
Spell it with me, C A U S E S, causes.
Obviously the education system doesn't teach this basic shit anymore so I guess its up to Rollaclub to save the world from piss poor spelling and grammar.
Blowby can come from 3 places, head gasket blowing into oil return, valve guide seals, rings, even if you fix everything perfect it will still blow oil out so work on your catch tank first, make sure the rocker cover is baffled properly and that it goes to the top of your tank, there MUST be a return to the sump above oil level, this comes from the lowest point of the tank, it may fix your problems. and try spell check
Edited by curly
not everybody can spell properly but atleast that was like the only word he got wrong
