Taz_Rx Posted February 8, 2009 Report Share Posted February 8, 2009 Hi6 or 6A will not advance the curve, hence you cannot lock the dizzy (for NA) and expect good results. :yes: I'm pretty sure a Hi6 is also analog btw!! You need to get something like below from either Crane or MSD for it to be a digi unit.... http://cgi.ebay.com.au/msd-digital-6plus-i...A1%7C240%3A1318 Quote Link to comment Share on other sites More sharing options...
philbey Posted February 8, 2009 Report Share Posted February 8, 2009 (edited) Locked dizzy + Jaycar programmable timing computer + 6AL/Hi6 = timing control. Otherwise, just a stock dizzy with a CDI. The Crane is definitely digital, the Mallory 6A is also digital. Better rev limiting witout the need for Pills (just set the dial) AND something I forgot, the Tacho testing function to make sure your tach is accurate. Also there is a model Hi6 with 2 stage rev limiting if you want for staging etc. You can also get a plug in unit for step retard/manual retard control. The only thing the MSD digital 6 has over the Crane Hi6 is the Start Retard function and it's standard with Step retard. Plus you pay 300 bucks more for it. Edited February 8, 2009 by philbey Quote Link to comment Share on other sites More sharing options...
Ella Posted February 8, 2009 Author Report Share Posted February 8, 2009 hrmm interesting stuff you guys have to say there RE: the CDI systems will take it all into account when I'm buying, for now once the motors done will it be ok with new platinum plugs and my current GT40RT coil and the stock dizzy? Quote Link to comment Share on other sites More sharing options...
philbey Posted February 8, 2009 Report Share Posted February 8, 2009 Yeh, you'll be fine with that to get it running, main concern would be the timing advance, big cam and carbs will need between 10-20 degrees static advance. The lumpier you go, the more advance you'll need. This means that once your full advance would most likely be very high and could cause issues. Quote Link to comment Share on other sites More sharing options...
Ella Posted February 9, 2009 Author Report Share Posted February 9, 2009 static advance is like at idle right? Quote Link to comment Share on other sites More sharing options...
philbey Posted February 9, 2009 Report Share Posted February 9, 2009 Simply put, yes. In detail, Static means the advance your dizzy will have set when it is not running. Once your car increases revs, a set of weights inside the dizzy increase your advance to a set higher value. On top of this, many cars also run Vacuum advance, which is a little vacuum actuator that increases advance depending on engine load. Quote Link to comment Share on other sites More sharing options...
TRD ke70 Posted February 10, 2009 Report Share Posted February 10, 2009 i have a set of lifters here, if you are still looking for some? Quote Link to comment Share on other sites More sharing options...
Ella Posted February 10, 2009 Author Report Share Posted February 10, 2009 what are they? if they are 5K hydraulic lifters that would be an absolute godsend... Quote Link to comment Share on other sites More sharing options...
Ella Posted February 10, 2009 Author Report Share Posted February 10, 2009 Simply put, yes. In detail, Static means the advance your dizzy will have set when it is not running. Once your car increases revs, a set of weights inside the dizzy increase your advance to a set higher value. On top of this, many cars also run Vacuum advance, which is a little vacuum actuator that increases advance depending on engine load. yeah mines not hooked up, should i hook that up or would it be worth leaving it off? Quote Link to comment Share on other sites More sharing options...
kickn5k Posted February 11, 2009 Report Share Posted February 11, 2009 i firgue if ALL of repcos suppliers don't have em then a engine rebuilder (who would likely get his bits from repco anyways) probably wouldnt either... I would not think any worthy engine builder would buy anything from repco, as they are now only retail stores and don't make any engine parts anymore. Would come from suppliers like ACL/MAHLE or PRECISION international. I`ll do some research on customers that way and get a reply up. Is southport too far? stu. Quote Link to comment Share on other sites More sharing options...
Ella Posted February 11, 2009 Author Report Share Posted February 11, 2009 Where's southport? lol Quote Link to comment Share on other sites More sharing options...
Ella Posted February 11, 2009 Author Report Share Posted February 11, 2009 hrmm got myself a second hand set of lifters thanks to TRD ke70 cheers mate! guess the working of the motor is on the backburner for now, will put these in and see how she goeses Quote Link to comment Share on other sites More sharing options...
kickn5k Posted February 12, 2009 Report Share Posted February 12, 2009 Where's southport? lol Just north of surfers. http://maps.google.com.au/maps?hl=en&tab=wl But that guy is now retired, so ive just found out. :) Try these guys out in Northgate. A mate that used to live up there has used them in the past and thinks highlly of them. Mick Cashell engines and parts. 5/39 Toombul rd Northgate, QLD, 4013 Hope that helps stu. Quote Link to comment Share on other sites More sharing options...
Ella Posted February 12, 2009 Author Report Share Posted February 12, 2009 Well after talking about a few possibilities as to what may be the problem to TRD ke70 when i got the lifters off him last night we discussed a few possibilites which i investigated this after noon in better light, turbs out he was quite correct in assuming the old owner of the car had built the motor with a 4k head gasket (fkn lol) and this may very well have been my problem all along, though probably also a collapsed lifter, so as soon as i can lay my grubby hands on a gasket ill be re assembling her with the new lifters and seeing how it goes :lolcry: keep you all posted :dance: Quote Link to comment Share on other sites More sharing options...
