Ke 35 Front Windscreen ?
Hi all
I need to replace my front windscreen on my ke35 and as they aren't very common i wanted to know if any other corolla screens would fit it. i know KE 3x front panels can be swaped so hopefully I'm in luck with the windscreen.
Aren't coupe guards a bit longer than sedan guards also? Or is that just my mind playing tricks on me?
Guards are the same. It's the same as the 2x series.
Try and get a new screen. It should only set you back $200-ish, and you'll be able to see out of it. :y:
Edited by Redwarf
Thanks all for the info.
ke 3x screens wont fit bugger. :y:
the screen unfortunately has one single crack slowly creeping down the middle of the windscreen. it wont pass rego in a months time so it needs to be replaced. figure i better start looking for one now as they aren't the easiest item to find (at least not within in close travelling distance from me).
Thanks again for the info
Cheers Jacob
Your mind is playing tricks on you. Upto the a pillar the cars are the same.
I thought it might have been playing tricks on me. My bad.
National Auto Glass Supplies 5 Jindalee Pl, Riverwood, NSW 2210
p: 02 95849888
they will have it, unfortunately they JUST put there prices up
Edited by TC16
