March 13, 200917 yr comment_327431 Hi all I need to replace my front windscreen on my ke35 and as they aren't very common i wanted to know if any other corolla screens would fit it. i know KE 3x front panels can be swaped so hopefully I'm in luck with the windscreen. Cheers Report
March 13, 200917 yr comment_327439 Only KE35 and KE55S screens will fit as they are more slanted. Report
March 13, 200917 yr comment_327441 Aren't coupe guards a bit longer than sedan guards also? Or is that just my mind playing tricks on me? Report
March 13, 200917 yr comment_327443 puff puff pass Your mind is playing tricks on you. Upto the a pillar the cars are the same. Report
March 13, 200917 yr comment_327444 Aren't coupe guards a bit longer than sedan guards also? Or is that just my mind playing tricks on me? Guards are the same. It's the same as the 2x series. Try and get a new screen. It should only set you back $200-ish, and you'll be able to see out of it. :y: Edited March 13, 200917 yr by Redwarf Report
March 13, 200917 yr Author comment_327450 Thanks all for the info. ke 3x screens wont fit bugger. :y: the screen unfortunately has one single crack slowly creeping down the middle of the windscreen. it wont pass rego in a months time so it needs to be replaced. figure i better start looking for one now as they aren't the easiest item to find (at least not within in close travelling distance from me). Thanks again for the info Cheers Jacob Report
March 13, 200917 yr comment_327454 Your mind is playing tricks on you. Upto the a pillar the cars are the same. I thought it might have been playing tricks on me. My bad. Report
March 14, 200917 yr comment_327771 National Auto Glass Supplies 5 Jindalee Pl, Riverwood, NSW 2210 p: 02 95849888 they will have it, unfortunately they JUST put there prices up Edited March 14, 200917 yr by TC16 Report
