Somethings a bit screwy there cause i always thought the bluetop made the 88kWs and the TVIS redtop made a bit more.
And you missed out the very first generation "Blacktop"
Thats the best photo i have
It more shows you which engines are the smallport and bigport versions right? and which model they came in?
Its just a photo i got shown which i thoguht was handy to have :P
I didnt make it and never looked into how accurate it was either
Travis
Absolutely Trav, I knew where you were coming from. And it is a good general guide.
Just making sure Michael knows to delve a bit deeper when he susses the motor out.
No worries
By the way, from what i gather
Is it the blue tops in that picture that are bigports? and the redtops that are smallports? but wasnt there some kind of 3 rib smallport?
And some 7 rib bigports?
Travis
EDIT: Also you know usually its a bigport or small port because of tvis right :P
Edited by trav_555
Should add to answer your specific question.
If it has TVIS it should be a bigport, no TVIS it is a smallport or someone has taken the TVIS off.......
But that is probably unlikely.
Assuming the engine number matches the car, simplest way to tell is from the spark plug valley cover. Bigport leads enter above each plug, smallport leads run underneath after entering at the front of the head.
We crossed there.
Earlier bigports are three rib, in rear and front wheel drive. There are later 7 rib bigports, all front wheel drive engines.
Positively no 3 rib smallports.
Sweet well surely all that information should be enough for him or anyone to figure out if there buying a smallport or bigport engine, i would assume so at least unless someone has something else to add
Travis
ADM bluetops made 86kw in the AE82 (and early import AW11s). The 96kw number is from the JDM AE86s. Supposedly series 3 ADM AE82s had the 7-rib bigport, which definitely had 88kw (same engine came out in AW11 MR2s, and early JDm AE92s)
Didn't think there were two blacktop generations (assuming you are referring to the 20v). Silvertop has two generations, you can tell by the number of throttle linkages.
you answered a question that has been bothering me. my KE25 has a JDM sprinter engine and i was always thought it was the 88kw engine but the guy i bought it off said it was the 100kw engine, I'm guessing he just rounded up the killawasps
Or he didn't know what he was talking about. Quite a few of those out there.
So what are the other differences between 1st and 2nd gen silvertops??
I ask this as I am currently installing a 2nd gen and just curious?? :P
