Noisy Bottom Pully
turns out my bottom pully is really noisy (4k) i thought bearing but a bloke at work swears it doesnt have one just some rubber stuff or something any ideas? oh n water pump shat itself anyone got a new one lying around
Why do you say it's noisy? There's no bearing on the pulleys, but some K engines have a pulley with a rubber section that might have thrashed out.
Any parts shop should be able to help you with a water pump, no point putting in an old one.
yeah its noisy as soon as i spray wd40 on it goes quiete. whats this rubber bit u speak of??
think he is taking about the oil seal
nothing should really but making noise down there
replace the oil seal and see if that fixes it
The fan belt is the problem replace it with a new one and make sure it's tight
No 5k crank pulleys are 2 pieces of steel sandwiching a rubber seal. Wouldn't be this though.
As mentioned above it sound like you problem is just a noisy belt (ie goes with a spray of WD40). Replace it and come back to us. :)
What do you mean by the water pump shaft shat itself as well? Are the seals leaking, or is it bent? Because if there's any chance it's bent then that's probably the cause of the noise.
And yes, I was talking about the rubber in the balancer, not the front oil seal.
whats this rubber ur talking about is it on the inside of the pully?
its definatly not the belt squeeking i know that noise and its not that at all got the water pump out get new one tommorro hopefully keep u posted then
pulled the pully off when i had the front of my car apart cos I'm not doing it twice pulled off the bottom pully and the back half is fairly worn so it the seal but only prob is can't get the seal out any hot tips?? :lol: oh water pump in nice n shinney
The front main seal?
Just lever it out with a flat screw driver. Don't be afraid to damage it (it'll happen) as you're replacing it.
I still don't exactly see how a front main seal can be noisey anyway!!! :lol:
yeah neither can i but thought f@$k it ill do it while shit is apart keep u posted how i go
It shouldn't be the seal, unless it's not seated correctly. If it makes that much noise, I'd be guessing that it's knackered anyway and you should be seeing lots of oil....
Screwdriver it out but take care not to score the faces of the engine block when you do it.
well the seal is very hard! and after further inspection the pully shaft doesnt look to healthy so not 100% sure but probably replace seal n pully while its off may as well! the front seal doesnt stop oil coming out it stops stuff eg dirt dust grime into my block and into my oil its a swipe seal..
