Calam05 Posted August 10, 2009 Report Posted August 10, 2009 are spacers legal? btw this is the coolest thing ive ever seen on a forum................ ........... . //______________________\\ /_________________________\ [__|__|__]------- ----[__|__|__] \________|MUZKE30|_______ / . \__OO__________________ / thats freakin awesome!! Quote
KE55PIG Posted August 10, 2009 Author Report Posted August 10, 2009 ok so i will be needing more of a -1 kinda ofset Quote
KE55PIG Posted August 10, 2009 Author Report Posted August 10, 2009 ok guys what sort of ofset will i need to get these wheels sticking outside of the guards ?? Quote
DearmanKE Posted August 10, 2009 Report Posted August 10, 2009 a 5 ml spacer will clear the strut easy y0, Quote
KE55PIG Posted August 10, 2009 Author Report Posted August 10, 2009 but i want to know I'm getting some 14x6 +17 hotwires i want to know how far of will they be from being wider then my guards i want wide track Quote
ke30r Posted August 10, 2009 Report Posted August 10, 2009 iv got 13x7 -19 offset on the rear with 20mm spacers on my 30 and the wheels are probably 10 to 15 mm past the guards Quote
KE55PIG Posted August 10, 2009 Author Report Posted August 10, 2009 so that work out to like a -40 that would mean ill need like a 60ml spacers Quote
DearmanKE Posted August 10, 2009 Report Posted August 10, 2009 also a 7 inch wide rim is 17.5mm wider on each side, Eg a 0 offset 7 inch rim will fill out the gaurd 17.5 mm more than a 0 offset 6 inch wide rim Quote
Hiro Protagonist Posted August 10, 2009 Report Posted August 10, 2009 Just as an aside, 14x7 +8 MA61 wheels are the _perfect_ offset for a KE30/55, fill the stock guards beautifully, and don't rub on struts or anything (not at stock ride height at least) Quote
DearmanKE Posted August 10, 2009 Report Posted August 10, 2009 yeah and they are quite good for a ke70, tho with a 5mm spacer i got defected for track (cop wrote on defect notice, wheels to not protrude from guard) Quote
KE55PIG Posted August 10, 2009 Author Report Posted August 10, 2009 who can get me a set of plates i can buy ??? to rego me car. ?? also i think ill get a 25 ml bolt on spacers with 5ml slipons for the car. Quote
adam-__- Posted August 11, 2009 Report Posted August 11, 2009 http://www.1010tires.com/WheelOffsetCalculator.asp Use this calculator to compare current wheels offsetting to desired. Trial and error with different sizes until you get it sitting in your preferred position. Quote
