Ke70 Build
dude, there are plenty of conversion kits avaialble that include modified engine mounts to fit a CA18 or SR20 into an AE86... which means with an AE71 crossmember they will suit your KE70.
Have a search around, they do exist. Perhaps Kaizen garage still has them? (he did about 5 years ago)
i'd just avoid doing the S13 suspension.
  • Replies 54
  • Views 73.5k
  • joeyjoejoejuniorshabadoo
    yeah, but you try having >300rwkw in your daily and then having 50rwkw in your drift car..... epic fail :P
way of subject i now but does ae71 crosmber fit on ke55 so i could do one of the above conversions
not to ignore advice here, i'm still looking at all angles... but how heavy are we talking? is it livable? or am i seriously gonna get pissed off and change things later?
i'm only building a drift hack, to smash around in..... and i don't wanna spend massive amounts of cash again...
It will be livable (for want of a better word) if you are only using as a track hack. I used mine on the street and at any sort of low speed turning it was unbearable. It just got heavier and heavier the slower you went.
There are plenty of options other than S13 front suspension, and don't just say you are doing it for the coilovers. There are enough coilovers out there these days you are bound to be able to pick up some second hand AE86 ones for the front and it won't muck up the geometry or the steering feel.
sweet as guys... will look more into the non s13 suspension side of things....
i'm off to look @ a ke70 now, with an ae71 crossmember, corona struts and sigma control arms....
iv started doin my sr conversion into ke70, heres the link to my build thread so far, not very far into it yet tho
http://www.ae86drivingclub.com.au/forums/s...read.php?t=2291
edit: BTW I'm doing s13 suspension and s13 sus works fine (if you don't mind the extra track and camber) if you use all nissan parts eg-x member, coilovers, brakes, hubs, control arms...
search for simonke70's ke70 on ae86 dc he's done s13 suspension and is apparently 1 of the best steerers out there. most the well known names running sr in there ke's have s13 front apparently...
simons sr20 ke70 build thread, well worth a look
http://www.ae86drivingclub.com.au/forums/s...hread.php?t=721
Edited by corey70
funny how theres about 3 people saying not to do it on that forum /\
the geomergy is all on the piss with s13 stuff not because of the longer lower arms but because the there designed to run fwd offset wheels, so the strut (which everything pivots around) is in a different place in regards to the hub which messes everything up, and of course you will detroy wheel bearings because your running 0 offset rims on suspension designed for +35
but you can make anything work by changing driving style and messing with bits but why bother, you'll spend more in devolopment and still not be as good as toyota stuff
just my 2 cents
yeah, gonna stick with toyota stuff for suspension and prolly gonna throw in a 4age for the meantime (12 moths odd) as its had the ae71 conversion done already
anyone know of a good 4age? :dance:
You only need to see this pic to notice the potential hotness of a KE70
cool, 4age makes for a really nicely balanced car!
will let you dail it all in and spend the $ on suspension and get the car doing what you want before the sr swap
get into it!!!
i like...
are you gonna chuck a cage in it?
Good to hear the project has begun!
I've seen this car a few times a meets, will be good to see another 4AGE powered E7 around..
