December 30, 200322 yr Author comment_3487 gawd - i need to live on the south side - most of the things i need to get / find are ova the line in shelby-vill..! Report
December 30, 200322 yr comment_3521 Teddy: 32712411 They are probably (AFAIK) the cheapest wreckers near Brisbane, I get a lot of my parts from there. And then on the way back you can stop by ABC Wreckers, and then Salisbury Wreckers. :ninja: Else, Kelly Wrecking in Zilmere's pretty good too... Report
December 31, 200322 yr Author comment_3543 thanks rob - ill give em a call on the 2nd when things are open again! Cya - Happy new year all! Report
January 23, 200422 yr Author comment_4272 I havnt done my research latelly, but if i did go and get aircon put in my car, would it be cheaper / more worth wile to find the origonal air con components, or get brand new 1's? P.S - i found a convertor at j-car from 24V to 12 V - the one id need for an aircon, just unda the 1 K mark :D - not worth it ! Report
January 23, 200422 yr comment_4273 Why would you need a 24-12V converter??? It would be worth your while to look around the wreckers for a factory setup. Buying new components (whether of factory setup or aftermarket) will never be cheap. Report
January 24, 200422 yr Author comment_4300 My crazy idea many posts ago about an aircon in my boot. Sounds like a good idea. Thanks demuire, Teddy Report
February 11, 200422 yr Author comment_5258 Yup, I'm back on the topic ! THis time, its slightly different! When u put the blower on in the ke70, it only comes out the 2 middle vents. how hard is it to set it up so that u get blower air from all 4 vents? (2 sides and 2 middle) ? Cheers Teddy Report
February 11, 200422 yr comment_5261 Not hard. Just need to get some flexible ducting and reduct it. The side vents do vent outside air in though, so if you closed those off (to vent from the fan instead) it might get a little stuffy... Report
February 11, 200422 yr Author comment_5267 Sounds like too much work - ill leave it how it is ! Report
June 8, 200422 yr Author comment_11133 Just to put a close to this chapter, Teddy finally got aicon for his corolla. Hehehehehe Report
June 8, 200422 yr comment_11144 the lack of fuel economy the damn annoying part that is missing from the system and is a bitch to find because the car is an import etc etc oh, hangon.. the second part is me ;) :insane: Report
