May 30, 200917 yr comment_348652 Hey guys, I own a 89 rolla sx and am getting taller and taller it is becoming a problem and i need to know what i can do. new rails?? new seat? i was thinkin maybe a camry seat? would they fit?? any help will be appreciated cheers Report
May 31, 200917 yr comment_348781 if you can tollerate it some of the single piece race seats are very thin from the base to the inside-middle. That with some low profile seat rails and its about as low as your going to get it. Report
May 31, 200917 yr comment_348913 Having said that, how tall are you? And is the problem height (ie head hitting roof, or knees hitting steering wheel) or length (legs bunching up) And just bolting in another seat from another car probably won't solve your problem, chances are they'll be just as big or bigger (and Camry seats tend to be quite big and comfy, as it's a family car), it's a real luck-of-the-draw Report
June 2, 200917 yr Author comment_349359 Having said that, how tall are you? And is the problem height (ie head hitting roof, or knees hitting steering wheel) or length (legs bunching up) And just bolting in another seat from another car probably won't solve your problem, chances are they'll be just as big or bigger (and Camry seats tend to be quite big and comfy, as it's a family car), it's a real luck-of-the-draw thanks for your help, I'm 6'6 so its my legs that are pushing it, headroom is fine, ill try the wreckers for a camry seat and see how it goes. thanks again Report
June 4, 200917 yr comment_349744 yeah id suggest some sort of bucket/racing seat i recenetly put a recaro bucket in my ke, its a recliner style. but i swear i sit like 80mm lower, and can sit 100mm+ further back. also if you get a recliner style seat, the seat mounts on the bottom are very easy to move further back so you can get more leg room. Report
June 5, 200917 yr comment_350176 if its not headroom then maybe a steering wheel spacer and spacing your seat back would do the trick Report
