Well here is the latest news
I have quit my job and have a bit of time so i have put the bitch into the garage to bleed and do all the brakes
i have gravety fed two cylinders so far and have two to go hopfully no dramas but it is an old corolla so here's hopin all is good
stay tuned
Woz
Thanks
i just had a look at yours it looks pretty good did you paint with enamel or acrilyc ?
Woz
Yeah painted it with enamel, I'm on the cheap arse budget build, trying to save more money for better things like suspension
If it's any condolences the last time i had to bleed my brakes ended up replacing the master cylinder as couldn't get pressure, then had a second crack at it and found the pipe from the brake fluid pot was slighty split and sucking air into the system, hopefully you have better luck
Edited by crispyke35
stay tuned
Woz
yeah all brakes done no problems stops on a dime :y:
  • 4 weeks later...
