i will be happy with 100rwkw. which i don't see as unrealistic with a nice tune, extractors and raised comp (from thinner headgasket)
if i was putting in some bigger cams i would go toda so i can still retain the VVTI, and not too large something like 264 or 272 with 9mm lift, would get a mild port and polish and a valve job too.
with these mods i would be expecting about 110-115rwkw. which is plenty. a corolla is never going to be fast in a straight line but the way i see it is straight line speed is for people who can't drive.
  • Replies 45
That sort of power level (110rwkw) would still be quite driveable and enjoyable. Revs is where it's at with these things and there is nothing like the sound of open trumpets at 8000 + rpm on a winding road, I should know :)
Good luck with it mate, I'll leave this for other people to make comments now :)
Luke what people feel is quick is pretty relative. Most people think my car hauls arse, I think it's reasonable. Axentrik might be happy with the power of something atmo. I agree with your comments about it being a nice package though.
Now Axentrik you may need to go to a 280 degree exhaust cam to get 110kw, but that depends on the dyno. Go to the right (wrong?) dyno with a stock 20v thats been tuned and you will see well over that. The right grind of 272 cams will work just fine with VVT and works well.
For a gasket the 0.8mm trd is cheap, easy and proven. With your compression raised to 11:1 with it its more than enough unless your running serious cams. As a bonus your engine remains a non interference type, trust me this I know without a doubt.
If you need some tips on your conversion or conversion parts then let us know.
ahhh sam q you are just the man whose input i needed in my build thread. you know practically everything worth knowing about 20v 4ages.
couple of things id like to know about the Silver Tops.
1.what is the stock head gasket width of an AE101 4AGE?
2.what is the stock cam duration and lift?
and secondly with the following specs, do you think 100rwkw is a realistic power figure on a not so number happy dyno?
0.8mm TRD head gasket
TRD Copy extractors
ecu and a good tune.
Edited by Axentrik
Very true, after all I have had a Sprinter with 180 rwkw and I would consider that quick. Driveable no, quick yes :)
And I agree I have had people come in my car and be amazed by it, which is good for the ego. I think the 20V is a good upgrade for these cars no matter what :)
Yes you're right..
its a VH Pacer Replica.
Full RT Interior
very lumpy 265 Hemi
4 Barrel Carb
Aunger (jelly beans) with red wall tyres.
And if you have 12k its all yours.
Edited by Axentrik
so i scored a set of these 4 Keihin carbs for the sweet sweet price of $0.00, THANKS DAD!!!
unfortunately they are not FCR but CV-K's off an 85 GPZ900
thinking about ghetto rigging them up to my 4ac for a bit of a learning process/free powaaz.
any thoughts?
Edited by Axentrik
ok just realised this wont be possible on a non cross flow engine as its too close to exhaust. might have to chuck em on my 1.6 escort until i get a 4age and some proper r1 carbs.
Edited by Axentrik
TRD Copy extractors
err no and not even remotely close.
Ok 1: stock head gasket width is reported to be 1.2mm compressed although some say 1.15, I havent measured it myself.
2: 250 degrees at 0 lift and 7.97mm for intake and exhaust on the silvertop and 8.2mm on the intake of the block
3: depends on the dyno, between 75 to 125kw from the same engine on different dynos. But an average of 100rwkw average yes. DO a decent amount of porting and most inportant do a lot of match porting!
oh and sorry for the delay in reply
EDIT: running carbs your on your own to me they are a demon sent device and I as well as not knowing much about them consider them a horrid thing.
thank you for that information sam and yes certainly plan to get the head ported and polished.
will not be running carbs on the 20v thats kind of a step back from quad throttle bodies.
they are just gonna go on my crappy escort 1.6 litre until i step it up a notch with some 99 R1 Mikuni Flatslides on a 16v 4age.
Edited by Axentrik
