Bigport Map Sensor Part Numbers
i need the part numbers for a bigport map sensor or a map sensor itself
I've got a MAP sensor which was taken from a big port and has part number, '89421-12030'.
Edit: 4agespares003.jpg
Edited by adam-__-
awesome thank you heaps
Make sure you get one that has the matching plug to your loom.
The later bigports have a different loom plug. Various map sensed Toyota's of the same era had the same MAP sensor, just with variations on the bracket.
I have proper AE86 ones, AE82 twincam and another of some other Toyota I found at pickapart. All work just the same.
thats a good point but that one in the photo has a similar plug
if i get it wrong i could take it back no problems i recon
