Child Restraint Anchor Points In Ae92/3/4 Seca
Would anyone be able to provide with some picture and/or dimensions or child restraint anchor points in a AE92/3/4 SECA. I have no luck in getting the info for anchor placement for my hatchback. I can only seem to find info for mounting them in a sedan with metal parcel shelf. Any pics and or photos would be appreciated
i find that the best place in the car to restrain a child is the boot. haha.
haha. I totally agree
When i had the ae82 seca the restraint anchor points were located on the rear panel more or less under the tail gate, between the tail lights and inline where the rear passengers would sit.
If you can't find them where Parrot and i've just said have a look up on the ceiling just in front of the hatch - same thing, three anchor points in-line with the passengers.
And if you still can't find them - not every single car came with them as factory.
But anywhat, as a note just be a little cautious of putting your little one in the middle cause if your using the capsule style the harness will slip down between the split fold seat.
In the AE9x Seca there are 3 round plastic bungs covering the restraint points, right at the back between the tail lights. The middle one is lower than the other two. You'll spot them.
Yes, you are correct Towe...
You have to remove the three circular clips on the inner beaver panel trim and you'll see the threaded holes in there...
Note: Pic is from a hatch, there is only one hole on this trim in the Secas, the other two are in the outer side trims under the tail lights...
