i filled up on 130000km and now its 1300240 just over the empty point?
can a 4kc with a trimatic be that that unecomonical?
I'm shocked...
(worth swapping over to a 3kc carby?)
(how can i reset the mixtures?)
cheers
Evan
  • Replies 42
replace leads spark plugs air filter rotor button and dizzy cap probably points too and fuel filter
if you havnt already that is.
check tyre pressures.
check for leaks
set timing to 8-10 degrees. check vac advance is working
i would consider the 3k carby, or just put a carby kit through the 4k one, they can be economical, i used to get under 8 litres per hundred week after week even giving the car a flogging at times.
check compression too while your at it...
then see how you go.
oh, it is stock isnt it?
check for leaks
yea its bog stock, i had a look down the carby the other day and as soon you blimp the throttle the primary jet looks like its dripping down instead of becoming into a mist?
(on my other 3kc it was the opposite?)
all the advance things work (checked at tafe)
timing is set at 12?
dwell was set as per manual
all cylinders are at 160psi exept cylinder 4 its at 140psi? doesnt blow smoke
pressures are bumped rite up
Edited by Evan G
so long as its not pinging 12 is fine, mine ran around that for ages.
are all the other servicables up to date?
hard to diagnose a carby problem without seeing it, air flow is going to be different with the filter off though, and at idle there isnt much velocity so its not gonna atomise in the barrell all that well...
nah i mean when I'm doing around 2000rpm at idle and blimp the trottle it just drip fuel down the venturies istread of atomise it?
A bit of crap in the needle and seat?
possibly, how do i clean it out? use that tool to clean the oxy tips??
a blocked needle would make it run lean??
How many litres is a "full tank"? Last time I checked a "full tank" was not a standard of measurement. Remembering your fuel gauge is possibly out by a good whack the only way we're going to know how good/bad your fuel economy is, is if you can provide us with an accurate volume of fuel used.
sorry for not adding that mate, its a ke55 so 50L tank and theres around 7L left
so 43L for 250kms
Wow.... I mean traumatics are bad but thats just....wow!
So that works out to something like 17L/100km. I'm stunned its even possible for a corolla to get that much fuel through the motor. Just as a comparison my worst fuel consumption ever is in the silvia on the track at 23L/100km and thats flat out all the time. I'd be looking for outright fuel leaks if your spark plugs aren't fouled much.
hello my car has a 4k-u with a weber DGV 32/32 carb! with normal driving my car gets 250km with 20L... maybe you have a carb problem...change it and check again!!!
