September 2, 200917 yr comment_370811 ive got acess to a supra 1jz motor will it fit into my ke70 and is it legal Report
September 2, 200917 yr comment_370816 1. Yes ( with a bit of a chop chop choppy) 2. Maybe (depending on which state you live in.) If your not a member of toymods you may not be able to view this. http://www.toymods.net/forums/showthread.php?t=33676 Edited September 2, 200917 yr by decoop Report
September 3, 200917 yr comment_370897 Think carefully about the balance of the car. A turbo 4cyl may make as much power and be lighter in the nose. The 3SGE Altezza has a far sportier feel and better turn-in than the 1GFE 6cyl version. Report
June 3, 201016 yr comment_442283 ive got acess to a supra 1jz motor will it fit into my ke70 and is it legal it is possible and the car handle pretty good with the right suspension. check mine out on youtube/wingate92 Report
June 4, 201016 yr comment_442412 :abuse: wingate92, in one of those vids I can see through your firewall, not just suspension mods by the looks. Wish it was legal over here! Looks like a wild bit of gear, you mainly use it for drag or track work? Report
June 4, 201016 yr comment_442436 Why not just put it in, put coilovers with a nice big spring rate in them, and then pay alot of money to an engineer and it will be legal, on that note you have to make sure the engine mounts are manufactured perfectly and everything is up to scratch :abuse: just a useless piece of info for ya bud Report
April 10, 201214 yr comment_596463 hey Wingate how far did you have to cut into the firewall ?? Report
April 11, 201214 yr comment_596694 I measured up a 1j to go into my 20, just for shits and giggles. It'd need about 6 inches of wall work. :lolcry: Report
April 11, 201214 yr comment_596700 Anything will fit with the right amount of work. legal well try calling an engineer and give him the engine capacity and the cars factory GVM and he can tell you if it will be legal will need other upgrades as well. Report
