aww good stuff man!! yeah ebay have listings for 4agze/4age head gaskets, what thickness did you use?? and is it hard to do it? what other gasket will i need? eg inlet, exhaust ect ect sorry for all the questions i just like to be prepared
Cheers
um you need exhaust and intake gaskets, need to get some bluemax for the front water fitting. could do the cam cover gaskets and stuff too.
not sure the thickness of mine, you will need a deep 10mm 12hex socket to undo head bolts and cam bolts
Try getting a hold of a top end gasket kit (VRS?) Will have every gasket you need from the head gasket up.
I was looking for a headgasket and manifold gasket for my ute and it was like $40. compared to a top end kit that had all the gaskets i needed for $44.50. so it will probably work out cheaper.
fair enough then. Nothing out of J-land or US of A?
there are FULL gasket kits on ebay for like 400 bucks!!! but over the top but hey id have Every gasket under the sun,
Would any one want to do my headgasket for me?
