Sr20 Conversion To Ke55 Plus Rebuild Plus Pimpage
next big misson was to clean up and paint the rocker cover,thought about it for a bit ,and was going to take it off to do it,but well i took off the nuts, it wasstuck down pretty good,so decieded to leave it on there and just mask up the engine, took a fair while to do this part, inbetween running around getting bits and pieces was a long day!
was pretty dirty ,and the lettering had a bit of corosion on them ,
used prepsol and a scotchy,got all the old grease and dirt off,and sanded it up,
found out it was made of alloy so wanted to have a go at polishing up the lettering ....
  • Replies 642
  • Views 744.8k
  • few more small things ,stripped the intake manifold , was going to try polish this up but it was so very grainy,sanded a test area and tryed polishing it ,but it looked so crap that i gave up on that
  • pretty happy finished off the clutch pedal,,   welded on the pedal part       i made up a stoper plate and welded that on       couldnt find what i realy wanted to but ended up welding
  • Man this was an epic read. I came from Google looking for how to do an SR20 conversion and found the mother of all rebuilds..   THIS LOOKS AWESOME, to the point that I signed up to the forum just so
after the rocker cover was sanded then had a look at the lettering, started with 400 on these ones,
there were fairly smooth so didnt need to corse to start with,
can see the 400 took care of the surface corosion straight away...
didnt want any sludgey water geting into the spark plugs and all over the engine so
went crazy with the masking lol
process i used on these were 400 dry,600 wet,800 wet ,1200 wet,1500 wet
here its up to 800
you should of painted it first then just sandback the letters :yes: then clearcoat
heres at 1200...
had a break from that and went back to painting parts....
main pulley
plenium...
throttle body...
oil thingy...
idle air contraption (loving this matt black)
yeah thats one way, but keep watching ....... :cool:
finally after all the painting and parts baked and unmasked heres what i ended up with,see what i mean there was a few bits....
loving this colour :yes:
leaving those parts, back to the rocker cover ,here started polishing the lettering...
well looks alot better than it did....
then changed the spark plugs,the ones that came out wernt to bad,not sure if they were in there from factory,the ones i got were from america,iriduim ngks,the gap was set at 0.30, the site i got them off said that they were pre gapped ready to go, only thing was the old plugs had a gap of 0.36 plus not sure if thats casue they wear out or if thats what they were set at,any way ill leave them at that for the moment,
got all the old masking off and cleaned up ,spark plugs done , letters polished ,ready to mask and paint...
just before i went to do that had to shoot off and get some stuff,but as i was driving along in my daily roller ,(that never gets attention,just abuse) i hear this nasty sound coming from the brakes,thought to my self oh dear god hear we go more dramas lol,any way quickly or should i say slowly back to work ,using the hand brake most of the way ,
got there with out crashing into any one,lol any way jacked up the car and took the wheel off, this is what i found...
a nice gouge around the disk edge,most likely the horrible sound i was hearing,funny thing was the brakes seemed fine???? wierd,,
any way pulled the caliper off and found the brake pads were practicly non exsistant!!!maybe 0.5 of a mm of pad left :lolcry:
with a small stroke of luck i remembered i had a set of brand new pads that i bought for my other rolla about 3 years ago ,and i managed to find them! so was pleased at that, this is what the new pad looks like vs the stuft one,i know this is a little off topic but in the greater scheme of things the daily,is part of my build,with out it i couldnt get around lol
any way after a bit of stuffing around got the bits back to gether,bleed the brakes, took it for a quick test run, and they work great ,way better than before ,the pedal is firm as,just want to cain around so i can slam on the brakes hahaha, pitty the engine is stuft :bash:
any way that little drama out of the way back to work........
back to the rocker cover...
masking up....
spraying base.....
also painted the crank angle sensor cover......
2nd coat of colour
clear coat...
man I have an exedy organic HD clutch at home, perfect cond it's only 200km old you could have had for 100bux
\doh :bash: :lolcry:
love it can't wait to start on this ke30 with ca under the bonnet glad old mate hadnt got too far into the covershion
yeah thanks guys ,the colour turned out realy nice,slowly getting there ,bit of a mission on this part as I'm pretty much learning about engines and how everything goes together,so hopefully i havnt made to many mistakes so far,
Edited by JDM55
well did a couple more things today ,nothing huge just more put together stuff,been going hard out on this since thursday nite!,was trying to get as much done as i could by to day,but run outa steam lol,plus the daylight savings lost me an hour :glare:
any way more bits an pieces >>>>
thought id throw together the bits and pieces off the plenium,just so that was done and out of the way.
so heres the plenium,throttle body and idle valve thingo,
replaced a fresh gasket onto the plenium for the idle valve thing...
something about flat black dunno i like it...
all boted down with some nice s/s bolts
vs old
