4k Head
i put my 4k bp head on my 70 the other day put a new head gasket on and stuff
read th wrong tourke specs done it up too tight snapd a head bolt went to start it and its got no compression.
so i took the head off again?
any help?>
Did you reset the valve clearances?
NO only got a lil bit ov an clue what I'm doin. ;)
if you have snapped a head bolt that would alow for low compression, what do you mean by NO compression??
you will want to get that head bolt sorted out before you do anything else
but as stated make sure your valve clearances are set to specs
and wouldnt hurt to reface the valves while the head is out
do you speak any english sir?
well said ol' chap
if you speak proper english people will be able to help more without getting frustrated
Edited by kiahn
well said ol' chap
sorry i was in a hurry.
As Felix says, valve clearances. Valves are probably open non stop.
My 4K has a snapped head bolt and its fine. (Bought it like that)
What you need is a set of feeler gauges, your manual, a flathead screwdriver and a 12mm ring spanner.
yeh i know that now i have the gages not a manual tho
wats the clearances?
i believe it is in the FAQ
Intake 20mm
Exhaust 30mm
