November 11, 200916 yr comment_390369 My radiator is farked, any suggestions for an upgrade, or am i better off just getting it reconditioned? Cheers Report
November 11, 200916 yr comment_390371 Go the recon, or a custom aly one. Cost the same to replace as it does to get a little aly one made... or did last time I checked (~$300-$400). Report
November 11, 200916 yr comment_390376 to upgrade the easiest way recore using 3 cores or custom 3 cores not a bigger radiator. Report
November 11, 200916 yr comment_390527 Squeezed a KE30 radiator into mine but it wasn't the nicest fit........ Report
November 11, 200916 yr comment_390599 I have a VN commonwhore rad in my '55. Inlet/outlets are already in the right spot, just need to lengthen the top hose about 100mm wich can just be done by cutting to hose and inserting some old steel pipe. Only issue I would forsee in a ke20 though is weather it would fit width wise. Report
November 11, 200916 yr comment_390612 Yeh 10 and 20 radiators are really narrow so unless you want to chop chop chop away it's difficult. Report
November 12, 200916 yr comment_390663 i'd say just get a reco one or an alloy one made to the same size and fit a shroud. i have a reco-rad and shroud in my ke20 and i have never had it over heat. the only time i saw the temp start to go up was after 20 min in stop start traffic on a 30 degree day. Report
November 12, 200916 yr Author comment_390722 i'd say just get a reco one or an alloy one made to the same size and fit a shroud. i have a reco-rad and shroud in my ke20 and i have never had it over heat. the only time i saw the temp start to go up was after 20 min in stop start traffic on a 30 degree day. Anyone ever bought one of these before? http://cgi.ebay.com.au/TOYOTA-COROLLA-KE20...=item518df3a788 Report
November 12, 200916 yr comment_390865 Anyone ever bought one of these before? http://cgi.ebay.com.au/TOYOTA-COROLLA-KE20...=item518df3a788 Wouldn't have any hesitation buying from Phil's Rotaries. For helpful guys and good products! :) Report
