I have a VN commonwhore rad in my '55. Inlet/outlets are already in the right spot, just need to lengthen the top hose about 100mm wich can just be done by cutting to hose and inserting some old steel pipe.
Only issue I would forsee in a ke20 though is weather it would fit width wise.
i'd say just get a reco one or an alloy one made to the same size and fit a shroud. i have a reco-rad and shroud in my ke20 and i have never had it over heat. the only time i saw the temp start to go up was after 20 min in stop start traffic on a 30 degree day.
