Twin Throttle Bodies
Hmm, I have a feeling only the early 4G63's (VR4, Evo 1-3) would bolt onto the Starion transmission. After that they swapped it 180 degrees, I doubt it'd bolt on anymore... Then again, I could be wrong :P
You'd be right about that.
  • Replies 64
  • Views 64.6k
if your fitting an aftermarket ecu to a rwd 20v, just do away with the dizzy and use a crabk angle sensor.
yes 20v head fits other a series, like 5a and 7afe. even 2a
Does that mean no chop chop on the firewall?
And how hard are these crank angle cenors?How much roughly?
Ta ryan
4G64 is a 2.4L engine with even longer stroke than the 4G63. Similar blocks though, I think. 4G63 is the better engine
Good ol Mitsubishi :P Just the same the 4G61 block is pretty much the same as the 4G63, just not as tall :P
Mitsubishi 4G6x Engines
4G61: Bore = 82.3mm, Stroke = 75mm, Capacity = 1596cc
4G62: Bore = ?, Stroke = ?, Capacity = 1795cc
4G63: Bore = 85mm, Stroke = 88mm, Capacity = 1997cc
4G64: Bore = 86.5mm, Stroke = 100mm, Capacity = 2350cc
4G67: Bore = 81.5mm, Stroke = 88mm, Capacity = 1836cc
4G69: Bore = 87mm, Stroke = 100mm, Capacity = 2377cc
The 4G69 has Mivec, it's the motor used in the Grandis. And for those of you interested, the current Lancer (regular version, not Evo) uses the 4G94, which has 81.5mm bore, 95.8mm stroke, and a capacity of 1999cc. I hear Mitsubishi are considering putting out a Ralliart Lancer to bridge the gap between the VRX and the Evo. It's meant to be getting either a Mivec 2-litre or a 2.4L engine. If it is the 2.4L option, it'd probably be the Grandis motor, which means the engine mounts and gearbox bellhousing would be all set up for 4G63 engine swaps!
