July 19, 200521 yr Author comment_59004 Yes, tappet info would be much appreciated TRD ke70. I'm running thicker oil and its not helping though they are quieter than they used to be. Fire away!! Report
July 19, 200521 yr Author comment_59068 Thanks heaps man. I'll set it all up tomorrow or thursday and see how i go. Report
July 20, 200521 yr comment_59430 Wouldnt hurt to get a surface grind if your doing a headgasket to ensure the head is perfectly flat sometime a blown headgasket will form a little "track" where its blown and if its not corrected it`ll just blow again.008" inlet and .012" hot just in case you havent got metric feeler gauges :) . Report
July 20, 200521 yr Author comment_59480 i got a set of both, but thanks for that. head gasket is fine on this engine, no bubbles in the radiator, no milkshakes in the sump. :jamie: thanks again people. much appreciated. Report
July 21, 200521 yr Author comment_59628 Adjusted valves, didn't have a manual, so i was guessing it goes: inlet-exhaust-exhaust-inlet-inlet-exhaust-exhaust-inlet Is that correct? Cos the bastard now won't idle, and it's decided it wanted to run on 4, then 3, and now 2 cylinders. Edited July 21, 200521 yr by AE35 Report
July 21, 200521 yr Author comment_59734 Fixed. After a lot of rooting around checking and re-checking valves clearances (which i'll hafta do again tomorrow) i decided to whip the weber off. To my suprise (well, not really, i suspected it), the Lynx adaptor plate to the manifold had blown half the friggin gasket apart. Nothing a tube of Silastic can't fix :jamie: Thanks heaps for your help TRD ke70 and ROL-010?? i think. Much appreciated. Though i did snap off a spark plug. Will fix that tomorrow. Edited July 21, 200521 yr by AE35 Report
