Tire Scrub Need Help
ok ijust brought some rims last night and the off set is alittle f@$ked it rubs onthe bottem of the strut i was expecting rub but not on that ahhh how can i fix this proplem woth out massive bolt on spacers because i don't feel like flairing my gards out any help would be appreiated
cheers
cam
Nope- you're stuffed!
If I understand you correctly, the side of the tyre rubs on the strut, so it has to be moved away outwards.
So, spacers will do it, bending the strut to give +ve camber will do it, and if its the tyre not the rim, then narrower tyres might do it. If there is another hub that fits the bearings, the disc and the rim bolts AND moves it outwards you'll be in luck.
but otherwise just sell the rims and get a different offset. Spacers do stress the rim studs so anything over 10mm means it has to carry its own studs, and outwards offset stresses the stub axles although I've only heard of Hondas snapping stub axles from wide rims.
Did you do any work on how they will affect your handling, steering weight, turning circle and ackerman setup? That can sometimes go to shit with wide rims that move the centerline.
I'm going to put 175 \65s on it because its got 195on there now see wharts that like ??? give it a shot
Wow 195s...Thats wide. I have got 175 with 8mm spacers on my car.
anything with grater than +27 offset in a 7 will scrub on the strut,
bolt on spacers ...15 mm and roll the guards if they need it
i have run 15 x 7.5 +2 front with 195/50with a light roll
problem solved was the big ass tires that was on there grabin 5 mil spacers tonight running 175 65 14 on front and then the 195 65 14 0n back lmao :)
cheers all
cam cam
do you have the exact specs of the wheels?
cause 195 isnt exactly that big for a ke70, its like the perfect size for 15" on a ke70
i reckon your wheels are 5-6" and quite a positive offset...
don't know there all good now i have 175 tires on it so ;)
