February 14, 201016 yr comment_413563 going from a clock tash to a tacho dash, just wondering is it just a simple swap over? Had a search couldnt find anything. Edited February 14, 201016 yr by DR1FT Report
February 14, 201016 yr comment_413564 heyy man i have done that only a few months back all you have to do is pull the clock dash out an plug in the new dash all the wiring is there, but the speedo you still have to change over which isnt hard take the front of both dashes and swap the speedo's over and the kms will be the same i had no problems, if u do then post em up Scott Edited February 14, 201016 yr by scottiriver Report
February 14, 201016 yr comment_413753 this is easy peasy. you don't even need to unbolt anything to do this one. 1. look at clock 2. position taco about 1inch in front of clock 3. smash taco with rubber mallet leaving food everywhere Edited February 14, 201016 yr by rjenman Report
February 15, 201016 yr comment_413829 are the old el paso taco kits better then the home brand ones for this i heard the kit doesnt come with mince and stuff Report
February 15, 201016 yr comment_413834 Ah yes I'm surprised nobody mentioned that already. When installing your taco dash you WILL need to buy mince and cheese seperately. If your KE70 taco kit already HAS meat and cheese, I highly advise against using it unless you welcome sweet bacterial death from food poisoning, or you are Indonesian. Or a dog. Or both. Report
