Options For Ke20 Seats??
hey does anyone know if any later model corolla seats will go into ke20 mounts? or, kan i swap the ke20 rails onto say ke30/55 seats?
cheers
cheers
Would also like to know aswell.
Here's a few options that are "bolt in"
* Early KE30 seats('74-'76) with KE20 rails
* Autotechnica race seats with KE20 rails
Although with the KE30 seats the 'recliner' lever slightly fowls on the rails lever (nothing that a bit of bending wont fix....)
I have also found with the Autotechnica seats that you may need to put a small spacer on the outer side (Between seat & rail) depending on the seat shape.
I have used 2 different styles of Autotechnica seats & only 1 style needed this spacer (only 10-20mm) due to touching the 'B' pillar, therefore restricting seatbelt function.
Hope this helps with your search for comfort......
Dougy
Edited by PHATKE20S
ke20 rails will attach to ke70 seats without modification.
you will need to remove a plastic cover on the seat for the adjusting mechanism.
I bought some Autotechnica seats, they fitted but sat too high. And they were a bit wide for me, I prefer a tight seat.
I ended up with Mazda RX7 series v seats, but had to modify the seating mounts. That is, don't line up with original holes. These seats sat a fair bit lower too.
Edited by robj
supposedly Suzuki Swift GTi seats are a straight bolt-in
I have a pair of the GTi seats (series1) so I might have to check that out......
As far as KE70 seats go (I forgot those in my earlier post) they need to be the early type because the SlantyKE70/AE71 seats use a different rail setup (they're mounted on the side)
Dougy
Thanks ill see if i can find some cheap Autotechnica seats, it happened to be coincidence that you replied in this thread, as the car I might be getting seats for is you old KE20 (I'm buying it off Dan) I might see if there are other more subtle bucket seats though.
Hey would you be able to try these on asap to see if they fit cause there is a pair on ebay that end in 12 hrs.
did anyone end up finding out if the swift seats fit?
i've also heard that GTI Swift seats bolt straight into a Ke70 and would be interested in confirmation
:P
i know that swift seat will bolt in to a ke30 cause thats what i have in mine
Real nice too
does any one have any pics of the swift seats in a rolla?
is it only the gti swift seats? or all swift seats?
not sure but mine are gti seats. just used the ke30 seat rails bolted right in no cuting or any thing
