  • Replies 42
thanks guys for the help!!!
my dad said that his mate has the original trd book? which has all the part numbers for the parts that u could get including the upright kit i might give him a call and check on what is in the book and see if theres any help from that!
yeah i thought the inlet would be the hardest to do out of the lot, the gear shift could be modified eaisily I'm sure it can't be that hard can it??
see ya
jimi
You may need to do tunnel mods in a ke15/17 with an upright kit.
Just fitting a ke70 gearbox needs some tunnel massaging with a hammer. Fitting a box at an angle would need more work.
hey
yeah i was thinking that but I'm sure ill figure that out just got to get the car and start it then ill figure it out when i get to that part!
thanks for the advice guys
see ya
jimi
I thought the upright kits had a bellhousing to suit also?
Yeah they do "TRD uprighted K-T's". But they're the rarest of all of the K-T's. Put it this way - we can't even get a pic of one for the FAQ!!!!
Pretty much everything else in the TRD kits would be exceptably easy and cheap to re-produce.
That's a bummer. I was starting to think of a upright turbo k motor :happy: lol.
Could always do a dodgy and drill the holes where the bellhousing mounts to the gearbox in the position you need them to be
Why? The whole point of the upright conversion is for a straighter, smoother intake path for sidedraft carbies. ie. Less flow restriction and more room for filters.
Look at the following pic and you can see a couple of obvious flow restriction points.
Edited by Felix
FYI WPN36 - My engine is actually slightly uprighted (like maybe 5 degrees) just to get a little more clearance between the turbo and chassis rail.
That was the main reason I was thinking of it. For some more clearance down there. And also the the plenum I
getting made up might possibly have short straight runners so would be alot easier being upright. I still think it looks weird though lol. So used to seeing them slanted to the max :happy:
did you just shorten the drivers side mount and lentghen the passenger side slightly Si? And the shifter still have much room to come through? Or did you bend it abit to have it up straight still?
