April 8, 201016 yr comment_428083 hey guys just wonderin how much gear box oil a T50 takes L/ml because i am going to just fill it form the top where the shifter goes because i can't get to the filler plug any help would be greatly appreciated Regards Mike Report
April 8, 201016 yr comment_428084 hey guys just wonderin how much gear box oil a T50 takes L/ml because i am going to just fill it form the top where the shifter goes because i can't get to the filler plug any help would be greatly appreciated Regards Mike 2.6 Litres of 75W-85 is what most of the websites say http://www.datateck.com.au/lube/valv_auMS/default.asp Phil. Report
April 8, 201016 yr Author comment_428086 2.6 Litres of 75W-85 is what most of the websites say http://www.datateck.com.au/lube/valv_auMS/default.asp Phil. Cheers mate absolute legend Mike Report
April 9, 201016 yr comment_428329 Thats not what our FAQ says..... http://www.rollaclub.com/faq/index.php?title=Manual_Gearbox Regardless, just fill it through the filler hole until it dribbles back out. Report
April 9, 201016 yr comment_428446 Actually, none of those are accurate. According to the factory chassis manuals Early T type T50 1.54 litres Later A type T50 1.7 litres Report
April 10, 201016 yr comment_428535 Actually, none of those are accurate. Regardless, just fill it through the filler hole until it dribbles back out. Report
April 10, 201016 yr Author comment_428584 Actually, none of those are accurate. According to the factory chassis manuals Early T type T50 1.54 litres Later A type T50 1.7 litres yea mate i have the factory book and it said 1.7 as well i tried putting in 2.6 but it didnt want to go in so I'm guessing 1.7 is the correct amount Report
